Help would be appreciated!
hi! i have a 91 yota 4x4. I was wondering if i could get some input on a problem im having with my truck. When i drive foward or backwards...my left rear tire seems like it gets caught on sometihng and then releases.... makin a jerking and a thud kinda sound. The faster i go, the faster the jerking and harder! it seems like its onli coming from the left rear tire. i can see the left rear tire jerk. I checked the drive shaft and axle. all seems to be ok outside, but im sure its something inside.
thanks for ur help! :pat:
i found out wat the noise was. i towed my car to my mechanic and let him hear the sound. he said that i was probably a broken diff gear tooth. i drove the car SLOWLY across the street to my dad's shop and dumped the diff oil. After the oil was drained, i stuck my pinky up the drain hole and felt around. Loe and behold i found a chunk of metal, about 1/2"x1/2" floating around in there. I took a magnet on a stick and stuck it in the diff to see if i could fish the chunk out, but no luck.
i took my rear diff out tonight. it took a lil while, quite easy though. So i got the diff out, took a look, and... AHHHHHH!!!! my r&p are shot! there are two huge chunks missing from the pinion (2 teeth) and the ring is all beat up. im PRAYING that my locker is A-OK and that none of that got chewed up.
Now, wat im hoping for is that my gears are stock (dunno if prev owners re geared it) and that i can get a 3rd member for cheap at a yard and just swap them. I'll put my locker in some other time. Im trying to find out wat the stock ratios are. I have a 91 yota ext cab picup, 4x4, v6. i looked, and the ring gear has markings that say "372". so we'll see wat happens.
thankS!
thankS!
priest16
15
Aug 6, 2015 07:43 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
Dennisx2
Aug 4, 2015 01:26 PM
