Help Please!!!
S#*T.....,I just sheared off a rear lug stud! :mad:
I have have the drum off and was able to knock out the broke off stud, now how in the hell do I get the new one in???
Is there a trick anyone knows to get a new stud in a easy way.
If no tricks can someone please tell me how to remove the plate thing the studs are mounted to, step by step directions, pics, anything.....
I have a Haynes manual, but it doesnt cover replacing a wheel stud and a search found nothing....:rolleyes:
Please help, going on vacation soon and only have today to fix it!
Dont know about yours, but on my 94 truck I just put the stud in from the back side of the axel. I had to go in sideways and at an angle but it went right in. Once the threads were through so I could get a lug nut on it I did so and tightened it up. As I tightened, it pulled the stud on into the plate and all the way through the plate untill it seated properly. You should lub the threads a little and maybe the stud itself to aid it in being pulled through. Thats how it works on my 94. Maybe yours is the same.
