Help ! My 4runner takes to long to warm up .
Old Jan 14, 2005 | 02:17 PM
pfbmgd's Avatar
I have 97 4runner 2.7L with 130 000 km on it.Last winter it used to warm up pretty fast compared to this year .I just changed the thermostat and coolant .But it still takes a while to warm up .Definantly longer than last winter . What else should I check or do ?
Old Jan 14, 2005 | 02:21 PM
Yota4runner's Avatar
When was the last time your oil was changed? Could it be its just colder oustide then last year?
Hmm your in Toronto I see, then the coldness likely isn't it as we havent really had any really cold days lately.
Old Jan 14, 2005 | 02:23 PM
desert whomper's Avatar
my 22re pickup takes a long time to warm up too, even when its 70 outside. new oil thermostat and fluids too.
Old Jan 14, 2005 | 03:01 PM
ChickenLover's Avatar
Was it taking a long time to warm up before you changed the t-stat? If not, perhaps you put in a t-stat that opens at a different temp than your old one. The temp at which each t-stat opens should be stamped on it.
Old Jan 14, 2005 | 05:06 PM
pfbmgd's Avatar
I changed the thermostat because of the time it took for the truck to get warm .The replacement thermostat is a Toyota 82 degree . I also use Mobil 1 and i`m due for a change in 800 km .
Old Jan 14, 2005 | 05:13 PM
Marc's Avatar
How long is too long?
Old Jan 14, 2005 | 06:10 PM
pfbmgd's Avatar
It took about 2 km to warm up before (city driving ) .It takes about 4 to 5 km to get up to temprature .
Old Jan 14, 2005 | 10:12 PM
Heck, mine takes longer than that. It takes almost 10min at idle to warm up in the mornings. If I just jumped in and took off without letting it warm up first, it would take around 4 miles (freeway) to warm up. I don't think you have a problem.
Old Jan 15, 2005 | 08:18 AM
Marc's Avatar
I don't think that's a problem especially considering the temp. You must be about 0 Celsius I'm guessing. At -20 celcius it takes me 10 minutes for the the needle to register normal and 20 minutes before it's blowing full hot.
Old Jan 15, 2005 | 08:27 PM
93YODER's Avatar
Id double check that the thermostat is working properly.Just cuz its new doesnt mean its not junk.
Old Jan 24, 2005 | 05:35 PM
Watts&Volts's Avatar
I had the same, my thermostat was stuck open....took forever to warm up. Also not a bad idea to change the rad cap at this time also. They get weak after time.
jennygirl
Nov 17, 2015 11:24 AM
Jdgarrison
Oct 1, 2015 05:22 PM
marcusSRG
Jun 27, 2015 07:13 AM
slider417
Jun 22, 2015 10:18 AM
jmc88runner
Jun 18, 2015 03:39 PM
