Help!!!!
Old Feb 1, 2008 | 05:36 AM
Kindervb's Avatar
Help!!!!
I have a 2000 4Runner with CA emmissions and in December the CEL came on and I had P0420 code with 128K miles on it the CATS were replaced (not with OEM CATS) and all was good for 1 month then the CEL comes on again and it is the same code. I just repalced the upstream O2 sensor and now 2 days later get the same P0420 code. Will replacement of the downstream O2 sensor help or is the issue with not having OEM CATS, or do I just ignore the code?
Any help would be greatly appreciated.
Old Feb 2, 2008 | 06:41 AM
ninjarunner's Avatar
Ignore the code.... J/K look up URD and get the O2 simulator and you wont have to worry about the down stream O2 ever again.
Old Feb 2, 2008 | 01:46 PM
4rnr4nick's Avatar
i had an emissions code show up also...it couldnt hurt to try cleaning your maf sensor...
Old Feb 4, 2008 | 07:06 AM
Kindervb's Avatar
I went ahead and replaced the downstream O2 sensor, it looked to be in pretty rough shape a lot worse looking than the upstream one. I had fun getting the nuts loose they were rounded off. The MAF was cleaned not too long ago as I had that code pop up as well some time back.
I cleared the code Saturday night so I will see what happens now with 2 new sensors and 2 new Cats.
Old Feb 4, 2008 | 08:24 PM
fullmann's Avatar
I also have a re-occuring p0420 code.
I have found that mine will come on about a day after I fill up with garbage gas. seems to stay off if I use decent gas. it also seems to stay off longer after I installed my supercharger about a year ago.
Old Feb 5, 2008 | 04:45 AM
rearviewmirror's Avatar
Good luck passing...
Ambiguous thread titles FTL!
