Hard Steering Woes...
Old Feb 25, 2004 | 07:44 AM
Denk's Avatar
So lately, my steering has become very hard, as if the ps is not working at all. I knew I had a leak in the ps pump, so I rebuilt it with new o-rings and the what not. Still hard steering. I rebuilt the idler arm and had an alignment. Still hard steering. Also, when driving at freeway speed, the wheels feel like they want to wander and when hitting small bumps or newly patched holes in the road, the wheels wobble a little out of control as if you hit a rut and got stuck going left or right.
So what could this be due to. The only things I could think of would be:
1.steering box (not sure what the fault would be here)
2.OME steering stabilizer
3.bent tie rods? (not sure here either)
Any and all help appreciated. Steering is very important to me, and I don't wanna be up on a trail with hard steering and have it all of a sudden go out completely and find myself rolling down the mountain-side at a 40 degree pitch into whatever 4x4 oblivion lay waiting at the bottom.
Old Feb 25, 2004 | 07:53 AM
KING's Avatar
I think I'm experience about the same symptoms as you are but to a much lesser degree.
Old Feb 26, 2004 | 07:19 AM
Denk's Avatar
*bumpety do da*
Old Feb 26, 2004 | 07:57 AM
Marc's Avatar
Just a thought and not sure if this is the correct diagnostic procedure but if you removed either your pitman arm or the tie rod end on the pitman arm you could find out if the binding was in your steering box or not.
Old Feb 26, 2004 | 01:54 PM
22Ryota's Avatar
I've got the same problems except my steering wheel is out of whack to boot.. straight on my steering wheel equals a small right turn.
nvdesertrunner
May 11, 2020 08:18 PM
stoneboy91
Apr 5, 2016 05:17 PM
delmert
Sep 30, 2015 04:34 PM
Scotto6591
Sep 1, 2015 03:24 PM
Up&Down
Aug 11, 2015 10:04 AM
