Grey wire mod help!
Old Mar 14, 2007 | 05:37 PM
TRDrunner's Avatar
Grey wire mod help!
does the ABS light come on after you do the grey wire mod?
i just did mine and the RR DIFF LOCK light just keeps flashing and the ABS light doesnt light up either.
i didnt use sauter i just used a sauterless wire tap and a screw eye connector to do it.
and to ground does the paint have to be sanded down to metal for it to work?
im going to go try to see if it works back in stock.
Old Mar 14, 2007 | 05:39 PM
jrock's Avatar
whats the grey wire mod and why do it?
Old Mar 14, 2007 | 05:42 PM
99SR5's Avatar
im pretty sure the paint does have to be sanded off. i didnt do that mod but i think the abs light come on
Old Mar 14, 2007 | 05:48 PM
OSU4Runner's Avatar
Yes, when you engage the rear locker, your abs light should come on and the RR Lock light should stay on steady. Yes if you can't find a ground around that area without paint, then you need to sand some off so the terminal makes good contact.
The grey wire mod allows you to engage your rear locker, (if you have one) without being in 4lo...so you can pretty much engage it whenever you want, 4hi, 2hi, whatever..
Old Mar 14, 2007 | 05:49 PM
TRDrunner's Avatar
alright.
ill try that. thanks.
Old Mar 14, 2007 | 05:50 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
another note of interest, if your light is flashing, your *mod* is working. your mod is telling the locker to engage. the light is flashing because the locker can't engage. which this happens, you should try driving forward some and then backwards some and, if necessary, doing a "S" shape path. you need everything in the differential to line up properly for it to engage. that is normal behavior.
Old Mar 14, 2007 | 05:59 PM
TRDrunner's Avatar
i tried all that for about 10 minutes.
still no solid light or abs light.
Old Mar 14, 2007 | 06:03 PM
either sand your ground (bad grounds can do funny things) or reverse the mod and see how it acts. just temporarily connect the wire back to how it was before you cut it.
Old Mar 14, 2007 | 06:13 PM
TRDrunner's Avatar
i just sanded the ground to the metal and tried that.
that didnt work.
Old Mar 14, 2007 | 06:15 PM
reconnect it how it was and see how it acts.
Old Mar 14, 2007 | 06:26 PM
TRDrunner's Avatar
does the gauge of wire have to be the same as the stock one.
TRDrunner's Avatar
i just put it back stock and it works fine.
Old Mar 14, 2007 | 06:28 PM
gauge needs to be the same or bigger (fatter wire), definitely not smaller wire. what side did you ground?
Old Mar 14, 2007 | 06:30 PM
TRDrunner's Avatar
the one from the ecu.
i got the right ground.
maybe its the sauterless connectors.
Old Mar 14, 2007 | 06:31 PM
try that but it shouldnt be. a standard butt connector should work fine
Old Mar 14, 2007 | 06:37 PM
OSU4Runner's Avatar
Are you grounding the right side of the wire? You need to ground out the wire from the connector. Are you stripping the wire back far enough?
Old Mar 14, 2007 | 07:07 PM
TRDrunner's Avatar
im grounding the wire coming from the bottom of the ecu.
should i ground the other one?
Old Mar 14, 2007 | 07:10 PM
you splice into the end coming FROM the white connector
Old Mar 14, 2007 | 07:16 PM
TRDrunner's Avatar
well that solves my problems.
hahahahah.
Old Mar 14, 2007 | 07:18 PM
OSU4Runner's Avatar
lol...
