GM 200 amp alternator and dual Optimas in a 98 4Runner (pics)
Old Jan 27, 2005 | 09:22 PM
98LimitedCustomized's Avatar
*EDITED* GM 200 amp alternator and dual Optimas in a 98 4Runner (pics)
Finally I get to contribute! I've got lots of mods to show, which I will gradually do... hopefully I can help somebody out, cause I know I've received a ton of help from this board. Alright I run a big stereo and in the future will run more lights etc. (I like toys).... so I had a GM 200 amp alternator that would normally go in a full size truck or SUV modifed for a Toyota plug and I used some washers for an easy custom mount. I then used a Hellroaring Technologies battery isolator coupled with Optima Red and Yellow tops to complement the whole set up. I put in an Injen intake, in which I cut a total of about 3-4" off of so as to fit the second battery in the engine compartment without having to move anything else. I upgraded all the wiring to either 1/0 or 4 awg. By the way the alternator costed me $200 and since it's in a much larger housing you could have it built much bigger yet, for a lot cheaper than a Toyota sized alternator. My wiring isn't the prettiest, but my materials are good and the connections are solid and soldered like crazy. I will consider doing a full write up if anybody is interested. I guess I more or less want to show that you CAN do dual batteries under the hood without having to fabricate anything fancy. If you have any questions let them fly, I'm sure I can help. Oh and I apologize for the dirty everything.... I've got all my skid plates off and we had some crazy icy roads which translates into salt and sand in every crevice and surface....
GM alternator... notice the four washers to complete the perfect fit....
http://community.webshots.com/photo/...61282693hRgbMS
Overall engine compartment view:
http://community.webshots.com/photo/...61281515dTQzXo
Hellroaring isolator:
http://community.webshots.com/photo/...61281262mWtrvy
Extra battery and Injen intake:
http://community.webshots.com/photo/...61281789hNZtTG
Old Jan 27, 2005 | 09:29 PM
dwh91102's Avatar
none of your links work
Old Jan 27, 2005 | 09:33 PM
MorphiasX's Avatar
An error has occurred.
You do not appear to be the owner of this album.
Make sure you are logged in.
Please push the Back button on your browser to correct this problem.
Thank you.
It appears that you linked us to your pics from your account as you are logged in, try going to your pics when you are not logged in, and give us that link.
BTW, would the GM alternator work with the 3.0? Im pretty interested as i will be running a two amp setup for my sound system, as well as 2 sets of 150w KC Daylighters, as well as the normal power drain.
Old Jan 27, 2005 | 09:39 PM
Bumpin' Yota's Avatar
my 190amp toy alt isnt keeping up, so im thinking 350amp GM time.....
oh btw on those links....
Old Jan 27, 2005 | 09:47 PM
any idea how to post from webshots?
geez i'm behind on this kind of stuff!
Old Jan 27, 2005 | 09:59 PM
Sorry about that... obviously my first time... should work now!
Old Jan 28, 2005 | 04:44 AM
nice mod! ill have to swing by a junk yard and grab a dead GM alt big case and see if I can make it fit in my 2nd gen....
Old Jan 28, 2005 | 04:49 AM
FilthyRich's Avatar
nice install.
Old Jan 28, 2005 | 05:00 AM
MTL_4runner's Avatar
Very nice job on the install.
Old Jan 28, 2005 | 11:15 AM
MorphiasX's Avatar
What GM vehicles did that alternator come in, so i know what vehicles to look for in a junk yard? Do you know if it would fit that easily on the 3VZE?
Old Jan 28, 2005 | 11:38 AM
Mickdady's Avatar
Wow that Salt is crazy!! I could not live in a place like that knowing that it would eat my car up!
Nice install btw.
Old Jan 28, 2005 | 11:43 AM
speaking of salt....
yeah not to rob my own thread but here's an example of what a 1 hour drive did to my back window.... to tell you the truth our vehicles hold up pretty darn good to the salt... i used a product you can see in my webshots, which i'll do a post of coming up, but it's $85/gallon but will pretty much make your underbody invincible to the elements.... not 100% obviously but more on that later.... i'd rather have salt though.... in South Dakota they're cheap and put down "sand".... well this sand is more like ROCK so you can guarantee paint and window chips if you live there....
http://community.webshots.com/photo/...61283669yfWTGA
Old Jan 28, 2005 | 01:05 PM
Ironmike4x4's Avatar
He he he this is perfect! I have a '98 Runner and work for GM, so I will definitely get the generator for my Toy. I am going to run about 6 130 watt KC Hilights on my runner as soon as I get my light bar so it will definitely help out plus my winch if I could ever afford the TJM bumpers.
Old Jan 28, 2005 | 01:07 PM
Yeah, it sounds like the type of deal I did is JUST for you. I'd would strongly recommend the Hellroaring unit... it was around $200 but it's about as good as they come. Check out their site, there are different models for different applications. I don't normally brag a company up but the quality of the product and service are unlike any I've experienced!
Old Feb 3, 2005 | 09:14 AM
How did you "modify the plugs?"
Old Feb 14, 2005 | 10:03 PM
Shepherd's Avatar
The motorcraft filter for a 3.0 is the FL-793. I'm a tech at a Ford dealership i have been using them for years with no problems. 280K and still going strong.
Old Feb 14, 2005 | 10:05 PM
jimbo74's Avatar
can having a huge alternator effect anythign else in the truck negatively?
Old Feb 15, 2005 | 05:14 AM
No. The alternator will generate power based on the load applied to it.
.....so no load, spins with little effort.....big load, uses some HP to turn it.
Old Jul 13, 2006 | 03:11 PM
04 Rocko Taco's Avatar
ANy ideas yet if this GM alternator will fit well into the 3.4??? And also if it is rated at like 200 amps, what is the MR2 alt rated at that I have seen modded often on toy trucks?
AND did this alt have the same size pulley? or is sit different, and need larger/smaller belts? Or is it a direct bolt on with the toyota belt??
Old Jul 13, 2006 | 03:52 PM
BLKNBLU's Avatar
According to the author's signature, he has a 3.4 so I'm guessing that ...yes it does work with a 3.4.
