Gearing suggestions
Old Dec 27, 2006 | 12:28 PM
mmayotaman's Avatar
Gearing suggestions
I have a '97 tacoma runnin the 2.7 with the 5 speed, i have 31x10.5's on it right now and am not really able to use 5th gear. I am looking to lift it and start running 33's. Just wondering what gears would be the best to run and any other things i need to be aware of when i lift it.
Old Dec 27, 2006 | 10:42 PM
StretchASU's Avatar
4.88 gears
As for the lift:
Figure out what you are looking to use the truck for i.e. how often you wheel, dd condtions etc. There are a ton of options for front and rear lifts on your truck. Personally I like the 63" chevy's on the back since it replaces the entire leaf pack on both sides AND you can pick em up wicked cheap. Roughly 60 bucks then factor in 55 for the BudBuilt mounts. Up front, prob and OME setup and possibly a small spacer for leveling reasons.
AND
Get an alignment done and check it regularly. Bad alignment will kill some nice 33's or any tire for that matter.
This is all IMO...
Old Dec 28, 2006 | 04:00 PM
mmayotaman's Avatar
Thanks for the tips... Ill take that info about the lift into consideration when i get the money and time to get it and put it in.
Eggslinger
Jun 8, 2019 03:32 PM
mskalmus
May 28, 2017 07:51 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
Gevo
Jul 29, 2015 11:15 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
