Fuel Type?
Old Oct 12, 2006 | 04:40 AM
darkglass's Avatar
Fuel Type?
What fuel are you guys using? ie octane, manufacturer, etc. Is there a difference?
Old Oct 12, 2006 | 05:12 AM
Potomacduck's Avatar
I use Tier 1 (top tier) fuels only. They contain far higher amounts of deposit control additives than other gasolines.
The additives are the only difference.
Old Oct 12, 2006 | 05:25 AM
Toy-SkiTzo's Avatar
i put nothing less than mid grade in my truck dosnt really matter where i get it as long as its not citgo my truck always runs funny even on their super
Old Oct 12, 2006 | 07:57 AM
X-AWDriver's Avatar
Top tier gas here too. I've been running 85 with no problems lately but every few tankfuls I run 87 for good measure.
Old Oct 12, 2006 | 08:44 AM
Elton's Avatar
ive only used 87 in all my trucks
Old Oct 12, 2006 | 09:14 AM
UNR.Grad's Avatar
My runner pings on 87, so I have to use 89. I need to clean the MAF and see if that helps...
Old Oct 12, 2006 | 09:17 AM
flykrs1's Avatar
From AAA:
Gasoline Octane
Some motorists are under the false impression that premium-grade gasoline gives their car more power, better fuel economy, or a longer life. Some even think they are giving their car a "treat" by filling up with an occasional tank of premium. The reality is that using premium fuel in a vehicle that was designed to run on regular is a waste of money.
Premium fuel is needed by a handful of vehicles with high-performance engines. These vehicles require premium fuel to prevent pinging and its associated loss of power. Combustion chamber deposits in some older engines may cause pinging. In many cases, the least expensive fix is to use a higher grade of gasoline rather than to have the deposits mechanically removed.
Federal regulations require that all fuels sold in the United States contain detergents to prevent the build-up of deposits in the engine's combustion chamber. Several name-brand gasoline marketers promote their own fuel additive packages that have detergents formulated to clean up deposits. With few exceptions, their premium fuel contains the same additives as their other grades of fuel, including regular. Therefore, additives marketed to remove deposits, clean fuel injectors, and improve performance are generally viewed as a waste of money.
wafoogalla
Nov 2, 2016 11:02 AM
shisha1999
Sep 21, 2015 08:22 PM
Poppie51
Aug 2, 2015 11:29 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Fundy Rider
Jul 16, 2015 01:35 AM
