fuel rail 3vze
Old Mar 27, 2004 | 02:36 PM
joe d95's Avatar
fuel rail 3vze
here is another problem with my 3vze engine if someone could help. I broke a stud off top of intake where fuel rail attaches. Will the stud come out of the intake for replacement or am I doomed and must replace the intake? Also, do the injectors just push into the rails?
Some knowledgeable people in this forum. Can you help?
Thanks,
Old Mar 27, 2004 | 02:42 PM
Churnd's Avatar
Depends on if the stud screwed into the intake or if it was molded on as part of the intake itself. If it was the first, then you can drill it and thread in a screw extracter to back it out. Then replace it with a new stud. If it's the second, you might could get it welded back on if you take the intake off. Careful with that though, cuz it IS fuel.
Old Mar 27, 2004 | 02:49 PM
joe d95's Avatar
Thanks Chris, I tried with locking pliers and it wouldn't budge. It looks as if they are molded in, but then I can't really tell well enough to be sure.
Old Mar 27, 2004 | 05:22 PM
Churnd's Avatar
Maybe hit it with a few shots of PB Blaster and let it soak a while?
Old Mar 27, 2004 | 05:59 PM
miket223's Avatar
They're not molded in, they're threaded studs. I can't remember how many studs hold down each side of the fuel rail, it's at least 2 maybe 3. If it's 3 then I would just look into only attaching the rail with 2 studs and evaluate if it will be sufficient to hold things together.
Thanks,
Sep 4, 2015 09:27 AM
Hiluxtrucha
Jul 22, 2015 10:00 AM
smiley52
Jul 11, 2015 05:16 AM
crashburnoveride
Jul 10, 2015 06:39 AM
