Fuel leak under EFI
Old Dec 4, 2002 | 04:32 AM
jasons's Avatar
Fuel leak under EFI
Help! My 86 4runner 22re is leaking fuel underneath the Throttle body. It's hard to explain exactly where it is leaking from, but its squirting out the top of a plastic cap that is upside down. Any thoughts?
Old Dec 4, 2002 | 10:23 AM
jasons's Avatar
Well, i found out where the leak was, and took off the plastic cap and a screw came out. I screwed it back in, and it stopped leaking, and held fine while i drove to work. However, when lunch time came, and i started her up, it started leaking again. Could this be some kind of fuel drain that is connected to the first injector?
Old Dec 4, 2002 | 10:57 AM
Jay's Avatar
Jay
That is called the Pulsation Damper. It helps reduce the pressure fluctuations caused by the fuel injectors "pumping" fuel.
You need a new one.
Jay
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
raptor510
Feb 17, 2017 07:11 AM
nick b
Jul 11, 2015 04:38 AM
Avenged
Jul 9, 2015 07:55 AM
