Fuel Filter
Definitely go with Toyota recommended filter changes and OEM parts. That is why you have a yota in the first place. BTW - the fuel filter is under the drivers seat. You have to remove the splash guard first. I changed mine out last year no problem, but take your time.
Originally Posted by Toyofast
Why replace it? Is there a problem with it? At work(Toyota dealership) we don't replace nor sell that many fuel filters, especially on rigs from '96 and newer. Plus if you do decide to replace it why install a cheap crappy fuel filter when you can get a factory one for a couple bucks more? No reason to install a lesser part in a sesitive part of the truck...
I don't think it is a fair comparison between the fuel filter and the oil filter, oil recirculates through the filter over and over, fuel goes through one time and gets burnt up. That being said, if it is easy to change on the 3.4 then go for it, I drive a Runner w/ the 2.7 and the fuel filter is a huge pain to access, so mine is staying on.
#27
#28
That is very annoying that on the 3.4 the fuel filter is so easy to change, I just don't see why Toyota would bury it on the side of the engine block for the 2.7. My truck is around 90k and I wouldn't mind changing it, but I really don't feel like removing the plenum to do it.
#29
#30
The motivation for it was to be a cheap/easy update.
By attaching the fuel filter of the 22RE to an existing bolt hole on the engine, Toyota didn't have to make a new mount for it somewhere on the frame, nor rework the body fuel lines to accommodate an inline filter. The 2.7 was just a carry over, 'Hey, it worked on the 2.4, didn't it?'
#31
If one were feeling creative, one could conceivably add an inline filter at a more accessible point on the 2.7L equipped vehicles perhaps? But that still wouldn't fix the OE filter if it were clogged under the plenum there. There are universal inline filters available for fuel injected vehicles with various different types of threaded fittings. Just make sure the micron rating/beta ratio of the aftermarket add-on is similar to the OE specifications. I don't know how you'd tap into the fuel line though, since it's high pressure (35-45 psi or so?)
#33
As an Expert Toyota tech myself there is absolutely no need to change the fuel filter unless there has been a problem with the fuel or any other symtoms. I the 7 1/2 years I has replaced maybe 6 filters and those were due to some sort of contamination. Not to mention the fuel lines are very tight and easily stripped if your not careful. Hope this helps it is just a step and maintaince concern that really is not needed.
pyramid
Jul 30, 2015 10:05 AM
