Front End Vibration on 97 Runner
Old Nov 21, 2002 | 10:23 AM
ando1's Avatar
I am having this problem when braking, I have replaced the pads and the rotors only to have the problem come back in a couple of months. I looked at the tsbs for my rig and tsb# BR007-00 mentions vibration problems with the brakes. Unfortunately, my rig has 111K miles on it and the Yota dealership says they won't fix it under the tsb for free. Anyone have any insight/suggestions to fix the problem?
Thanks,
Andy
Old Feb 24, 2008 | 01:09 PM
MarkCia's Avatar
I have the same problem. Replaced Rotors,Pads & Steering Rack. Rotated tires still vibration in steering wheel while braking. My lower control arm bushings and ball joints are all original with 251.000 kl. replaced one inner tie rod. Mechanic told me to live with it. Truck is in excellent shape but the brake vibration is a downer..
Old Feb 24, 2008 | 01:28 PM
DeathCougar's Avatar
Sounds like you need new calipers. If one is hanging up or failing, it will be off balance and cause vibration.
Old Feb 24, 2008 | 01:46 PM
d0ubledown's Avatar
X2. binders need replacement or rebuild.
Old Feb 24, 2008 | 05:32 PM
dbcx's Avatar
1.Even with new rotors when they sit on the shelf they could warp. Have someone just knock the high side of off them, just a light slow cut(barely)
2. Are you wshing it right after driving? The cool hose water can cause that if you spray your wheels while they are hot.
Hope that helps those are some more obvious problems to check
truckmike26
Jul 24, 2024 10:24 AM
Daneums
Jun 29, 2015 06:38 AM
miceal383
Jun 29, 2015 12:27 AM
YotaGreenhorn
Jun 27, 2015 07:00 AM
94 First Responder
Jun 21, 2002 05:17 AM
