front end shake
Old Sep 16, 2014 | 04:35 PM
Polaris2012's Avatar
front end shake
I have a 2003 tacoma TRD with 82,000 miles v6 manual. At 65-75 mph it has a shake in the front end i can also feel it in the steering wheel. It more of a shake then a vibration. Its worse when im going straight vs when im on a slight turn. Any thoughts on what it could be? Im not familiar with these front ends. ball joints dont feel like they are bad. it has new shocks and struts and new wheels and tires (about a year old) had the tires balanced and it didnt help at all.
Old Sep 16, 2014 | 05:15 PM
JasonYota's Avatar
Did you try rotating the tires to see if it stopped?
Old Sep 16, 2014 | 05:18 PM
yes I had them balanced and rotated and it didnt change
Old Sep 17, 2014 | 05:00 AM
JasonYota's Avatar
How about the alignment? Everything else is just about covered
Old Sep 18, 2014 | 06:52 PM
JustinD's Avatar
check the bushings on the steering rack and sway bars.
Old Sep 18, 2014 | 08:37 PM
Kiroshu's Avatar
X2 On possible worn/damaged steering gear mounting bushings.
Verify any excessive play in front steering/suspension parts.
Loose fastners..?
Loose wheel nuts..?
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
jasonty
41
Dec 23, 2018 01:00 PM
Daneums
Aug 20, 2015 05:36 AM
v_man
Jul 23, 2015 04:01 PM
