Front end noise
Old Dec 30, 2002 | 09:02 AM
Cebby's Avatar
Front end noise
This seems to have just started happening with the extra use of 4hi with all of our inclimate weather here.
When in 4Hi, turning left at slow speeds, I get what feels like binding as if my diff is locked. My inside wheel makes the vehicle raise up on that side a bit. Happens in forward and reverse. This is not even at full lock on the turn, but about half way. No problems or weird noises in 2WD. When I had the brakes done in September, could they have screwed something up when they put new rotors on?
I don't remember this happening before but it might have done it all along (wife drives this rig a good amount and is oblivious to vehicle noises - and warning lights for that matter), anyway, does it sound normal?
Old Dec 30, 2002 | 09:16 AM
Corey's Avatar
Co-Founder/Administrator
The binding you are experiencing is normal is you are not on a slippery service and you have 4WD engaged.
You have to be on gravel, loose packed dirt, ice, snow, ect.
If you just engage 4WD and drive on the streets in rain, even heavy rain, you will bind the 4WD system, and this will happen.
Old Dec 30, 2002 | 09:18 AM
UKMyers's Avatar
If it happens at only half turn that sounds a bit excessive to me. Mine binds up but only if going really slow and I turn almost all the way.
Sep 4, 2015 09:27 AM
Daneums
Aug 20, 2015 05:36 AM
razorman8669
Jul 12, 2015 12:13 PM
mlavery85
Jul 12, 2015 10:33 AM
Jonny246
Jul 12, 2015 04:51 AM
