Front diff/axle leak?
Old Jun 19, 2009 | 09:43 AM
Yukon's Avatar
Found some leaking diff fluid today while crawling around doing a check up. Need some ideas where to start with this. I cant search as the internet here is so crappy, it has taken me almost a half hour to post this.
here are some pics
This is upside down
here in a slightly differnt view
It looks like it is coming out right where the front half shaft (cant recall real name now..) comes out of the diff. If it helps there is a little play, towards the tire...
Ideas welcome. Need to get this fixed.
Thanks!
Also, Anyone have this piece for sale? its from the AC tension er.
Thanks again.
Old Jun 22, 2009 | 07:44 AM
Yukon's Avatar
Anyone have any ideas?
Old Jun 22, 2009 | 12:09 PM
crolison's Avatar
probably the axle seal on the diff, cheap part easy to fix. Just have to pull the cv out and pull the old seal and install a new one.
Old Jun 22, 2009 | 12:46 PM
hross14's Avatar
Make sure when you install it that the depth is correct or you will have problems. I couldnt see your picture but i am assuming it is the differential extension tube side. The depth needs to be .2" or 5.5 MM. I have discovered that usually only the dealer has those seals...
88sasturbotoy
Jan 30, 2026 01:57 PM
jasonty
41
Dec 23, 2018 01:00 PM
Ladythump
22
Nov 9, 2015 08:53 AM
andrewtexas123
Jul 14, 2015 04:29 AM
Avenged
Jul 9, 2015 07:55 AM
