Front diff/axle leak?
Found some leaking diff fluid today while crawling around doing a check up. Need some ideas where to start with this. I cant search as the internet here is so crappy, it has taken me almost a half hour to post this.
here are some pics
This is upside down
here in a slightly differnt view
It looks like it is coming out right where the front half shaft (cant recall real name now..) comes out of the diff. If it helps there is a little play, towards the tire...
Ideas welcome. Need to get this fixed.
Thanks!
Also, Anyone have this piece for sale? its from the AC tension er.
Thanks again.
here are some pics
This is upside down
Thanks!
Thanks again.
Make sure when you install it that the depth is correct or you will have problems. I couldnt see your picture but i am assuming it is the differential extension tube side. The depth needs to be .2" or 5.5 MM. I have discovered that usually only the dealer has those seals...
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
jasonty
41
Dec 23, 2018 01:00 PM
Avenged
Jul 9, 2015 07:55 AM
