Front axle seal. Need help.
Old Oct 21, 2009 | 09:10 AM
SWPERIC's Avatar
The front axle seal on the passanger side of my 2002 4runner was leaking slighlty after I swaped in a regeared diff. I must have mangled the seal while wrestling with the most frusterating axle system ever. I attemped to replace the seal. The first time I didn't have it in far enough. Then I got another and hammered it in with a huge socket. But it is leaking at a steady drip. How far in should push it in? Any tips for seal placement would b appreciated as well as any tips for getting those axles installed easier.
Old Oct 21, 2009 | 10:16 AM
Yukon's Avatar
Did you check your breather hose to make sure its clear?
It goes in so that its flush with the outside lip of the diff. as far as i remember right at least. Same distance and orientation as the one you took out.
Old Oct 21, 2009 | 10:27 AM
crolison's Avatar
IIRC you should have the surfaces flush together. I gotta replace a seal on mine friday while i'm throwing in a new diff.
Old Oct 21, 2009 | 03:47 PM
SWPERIC's Avatar
Ah I must have pushed it in too far. Bummer. I'll try backin it out if I can dream up way to do that
Old Oct 22, 2009 | 07:11 AM
hross14's Avatar
I have a write up on this--search for Hross14....it is under "leaky front axle seal" i do believe. It needs to be 2/10ths of an inch below the inner lip on the extension housing. Look it up--i describe the process and problems. Honestly if i were to do it again i would make an installation tool from wood so that it would go in perfectly.
Good luck
Henry
Old Oct 22, 2009 | 08:57 AM
SWPERIC's Avatar
here is henry's write up
i came to the same conclusion on my own. wish i would have searched harder instead of going thru 3 seals. crazy thing happened, a toyota dealership had the part and was open til midnight! so glad to get that job out of the way.
Old Oct 22, 2009 | 09:33 AM
hross14's Avatar
Congrats--Yeah its not a hard project but can be a pain if not done right...
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
