Fogs on TJM
Old Oct 1, 2005 | 08:33 PM
Localmotion's Avatar
Originally Posted by northfacer581
do people strengthen the frame for the warn m8000...thats the other winch i was considering getting. the only reason i would probably get the milemarker is because my friend is selling it for 200 (parting out truck). i know warn is better and its always nice to have the comfort of having a warn blah blah blah, but the milemarker is in great condition, seen him use it recently, no problems....ok hijack over, thanks for the answers
im not sure whether or not you need to build it up for the m8000. heres what steve did http://www.sonoransteel.com/tjm.html
I remember filthy saying that someone took a peice of angle iron and bolted it through the frame rail or something like that, in order to strengthen it up
Old Oct 1, 2005 | 08:39 PM
northfacer581's Avatar
yea i read steves writeup and just shot him an email. i know that the closer you get to a 90 degree pull the more stress you put on the winch/bumper, but would i really need to do anything to the bumper/frame for just simple straight line pulls?
Old Oct 1, 2005 | 08:45 PM
this is straight from TJM
"Most steel bull bars are designed to have a winch fitted directly to the bull bar, and do not require winch frames. The steel bull bars that do require winch frames are called "recessed roller" bars. This type of bull bar is a special design required for airbag compatibility on some vehicles.
All Aluminum bull bars require a steel winch frame to support a winch.
All winch capable bull bars fit up to a 9000 lb low mount Warn or Ramsey electric winch. Some bull bars such as the Ford Super Duty bull bar can accept a larger winch. Call your TJM Distributor to inquire if a larger winch will fit in the desired bull bar"
http://www.tjmbullbars.com/faq.htm#faq2
Old Oct 1, 2005 | 09:09 PM
thanks! looks like i will wait and see to put the winch inside the bumper if it will fit, and perhaps use a snatch block everytime to half the stress on the bumper.
Old Oct 3, 2005 | 12:49 PM
  #25
li_runner's Avatar
I believe as far as I've seen I'm the only one to put fogs down in that general area. I did not put them where you are suggesting though. You will need to fab up some brackets and weld them to the bumper. What I did, was to put the lights on the bracket that attaches to the frame.
Now I know that it's not the safest spot, but my truck doesn't see rocks, only sand so it works fine for me. The lights are hella micro ff.
Note the lovely NE rust from salt. Soon to be painted.
Old Oct 3, 2005 | 01:17 PM
  #26
shotking4's Avatar
Pete,
that looks pretty good. i actually have a set of those fogs because i bought that fog light kit from performance products before i had my tjm. they are just sitting in the bumper now in the backyard. Do you have any more pics of the brackets you fabbed up? maybe a closer up pick of the front? thanks for you help and you runner is awesome man, truly awesome. oh yeah, one more question, how's the light output? specifically, does the bumper hinder the light spread or anything? i'm assuming no since they are fogs and shoot their light low and wide, but just curious, thanks again.
Old Oct 4, 2005 | 06:42 AM
  #27
li_runner's Avatar
I didn't have to fab anything at all. The 96-98 TJM mounts have a gap between the bottom of the bracket and the bottom of the frame. It gives just enough room to drill a hole to mount the light.
The light is not blocked by anything, and is nice to have. Since in reality the lights on top of the TJM really only can be used sparingly (they blind everyone) the lights down lower can be used almost always. They don't bother most people when you drive by. They have a nice pattern down low making the road bright right in front of the truck where the regular headlights get cut off by the bumper.
Old Oct 4, 2005 | 07:03 AM
  #28
FilthyRich's Avatar
I would be worried about wheeling with the lights exposed like that.
Old Oct 4, 2005 | 07:05 AM
  #29
i agree. I dont want to ruin 160 lights on a rock. As soon as i make up my mind about which fog i want, ill get a pic up.
Old Oct 4, 2005 | 08:01 AM
  #30
li_runner's Avatar
I haven't had a problem yet, but yes they are exposed. I actually have spare parts for the lights because of a good e-bay deal I found back in the day. If you look at the side view, the TJM bracket covers the light from a forward hit. But other than that
Haven't had a problem yet, other than a rock hit on a snowy road trip up north skiing. But that happens a lot around here, as my windshield currently looks like I was in a drive by. Since I drive a lot in snow, I have had to replace my windshield nearly every year.
Old Oct 4, 2005 | 08:56 AM
  #31
jacksonpt's Avatar
Senior Member
How you going to mount the lights? You'd have to have them flush or recessed to keep them protected, and there's nothing back there to mount them to.
And yes, I was the one who put fogs in where the stock TJM turn signals are. I think a couple other people have done it as well.
Old Oct 4, 2005 | 11:28 AM
  #32
Ehinfinity's Avatar
I mounted my old fog lights from my OEM bumper on my T-17 using the same bracket as Li_Runner. Works fine and when they get crunched i will put 4 PIAA 001 Solitaire's behined the bumper in the holes. Ebay about $30-$40 a pair.
Eric
Old Nov 1, 2005 | 05:46 PM
  #33
Eric(filthyrich) and I were discussing the fog light situation ( cant make up my mind) and we came up wtih another idea.
1.
2.
here
Old Nov 1, 2005 | 05:48 PM
  #34
shazaam's Avatar
what happens when you mount the winch in there? that spot won't work. If your goign to be cutting holes in the bumper, cut them on the outside of the rubber bumper stops.
Old Nov 1, 2005 | 05:51 PM
  #35
I'm 99.99999% sure i wont be getting a winch. The conclusion was that if we cut holes on the other side....the direction of the light would be skewed b/c of the angles....if that makes sense
Old Nov 1, 2005 | 06:55 PM
  #36
do you guys think it will look bad with a 2 sets of lights almost right on top of each other.....yes yes...im a street queen
Old Nov 1, 2005 | 07:44 PM
  #37
BruceTS's Avatar
Originally Posted by li_runner
Those would only last me one trip offroad before I'd tear them off. I plan to re-do my turn signals and I'm gonna add fogs next to them. To deal with the skewed angle, I'll simply fabricate a shroud to angle them correctly.
Old Nov 1, 2005 | 07:55 PM
  #38
I agree. Thats why i wnated to do the idea in post #33
Old Nov 1, 2005 | 08:06 PM
  #39
4x4Lamm's Avatar
I thnk these would be the easiest to mount:
Performance Products sells em'
Get yourself a hole saw and youre set.
Lamm
Old Nov 1, 2005 | 08:09 PM
  #40
BruceTS's Avatar
okay I edited his photo to show how I plan to do mine
