Fog Light Problems....Suggestions?
I installed my Pilot fog lights under my rear bumper this afternoon. I finally got everything hooked up and threw the switch and nothing. Here's what I did...
I already had a Toyota fog switch in my dash controlling my Piaa 1000Xs. They were working fine until now. I ran the wire from the Pilot relay to the front and also the power wire from the Pilot relay to the front. The power wire went to the battery, and the relay wire went to the new Toyota switch that I bought to control the Pilots.
The Toyota switch, as I'm sure you are aware, has three prongs. Top goes to ground, middle to switched power, and the bottom to the relay. The wire I ran from the Pilot relay went to the bottom prong on the new switch. Instead of running addtional wires through the firewall, I put a jumper from the top prong on the Piaa Toyota switch to the top prong on the Pilot Toyota switch. I did the same for the switched power prongs. Well, like I said, niether the Piaas or the Pilots are working right now. The Piaas will come on, but do so when I turn the headlights on which isn't right. The Pilots don't work at all. Does anyone have any suggestions as to what might be wrong? Thanks guys. Later.
Matt
Matt
ashersullivan88yota
Jan 18, 2022 05:37 PM
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
