FIPK air filter system
Old Oct 28, 2004 | 11:36 AM
flyguy's Avatar
Has anyone tried the K&N 57 Series FIPK on there 4runner's and if so where there any noticable gains?
thanks for the help in adavance. I am looking at picking up one of these for a little extra horse power.
Old Oct 28, 2004 | 11:43 AM
4Hummer's Avatar
I bought one of the $9.99 units off ebay. Its the cone filter K&N Knock off. I've noticed considerable gains. Plus it gives the truck that nice deep sound
Old Oct 28, 2004 | 12:23 PM
X-AWDriver's Avatar
3rd gens owners generally just do a deckplate mod and get the same results with an Amsoil or K&N drop-in combination and is easy and cheap to do. I think I spent 13 bux.
Old Oct 28, 2004 | 12:33 PM
flyguy's Avatar
I have a 3rd gen, but I don't know what the deck plate mod is? Can you explain a little more.
thanks
Old Oct 28, 2004 | 12:47 PM
four.runner's Avatar
Rather than explain it all over again.... You can run a search on deckplate mod...or you can go to the Tech write-up section (Jacksonpt did a great write up on it)
I did the airbox mod on my 2nd gen, and it was a marked improvement over stock. (I have a k&n drop in filtercharger)
Old Oct 28, 2004 | 01:02 PM
FilthyRich's Avatar
I had the FIPK and what piece of poop. It sounds real deep and throaty, but it is NO good on my 3rd gen. After a couple hundred miles it threw my CEL and no matter how many times i cleaned my MAF the light came back.
Save yourself money and go with an Amsoil drop in and deckplate mod.
Old Oct 28, 2004 | 01:26 PM
snwbrdpunk16's Avatar
Sounds to me like you had a maf problem. I've had mine on for about 30k miles, and havent had on problem, expect it likes to suck in water when u get in the deep stuff, but thats obvious.
IF you are going to be doing a lot of offroad in wet areas, do the deckplate, the open airfilter is no good.
Old Oct 28, 2004 | 03:05 PM
mtxride's Avatar
I had a FIPK but switched to a stock box with the deckplate mod. power is about the same both ways, so save your money and just do the deckplate and ISR mods.
Old Oct 28, 2004 | 03:19 PM
jdecker's Avatar
check gadgets site deck plate makes more horse power. stock box also makes more horse power.
Old Oct 28, 2004 | 04:22 PM
MTL_4runner's Avatar
Deckplate mod and Amsoil filter is by far the cheapest and most effective way to mod your 3rd gen.
.....skip the FIPK like most on here have done.
Old Oct 28, 2004 | 05:38 PM
tarheelrunner's Avatar
I've got the FIPK and I really like it. Makes the 4runner sound a little deeper and has helped some with power. Kind of expensive though (I think I paid $230) so if the deckplate mod really works as well as everybody says it does than I'd probably look into it if I were you.
Old Oct 28, 2004 | 06:00 PM
Chapman88SR5's Avatar
have u thought of switching around the battery and intake box? and then do the deckplate mod and the drop in filter
Old Oct 28, 2004 | 06:10 PM
FilthyRich's Avatar
The FIPK did not work in MY 4runner. I am not saying that it doesn't work. What I am saying is that for some reason it seems to be hit or miss if the FIPK is a positive upgrade. As soon as i pulled it off and cleaned the MAF, I have never had another problem--that was 15k miles ago. Just my $.02
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
ryerye13
Jul 14, 2015 08:27 AM
