Extra HP, and Tire Size adaptation
Old Dec 4, 2004 | 09:48 AM
M3Man02's Avatar
Hey there guys, I have seen that superlift has an electronic thing that you plug in and it corrects for bigger tires. And there are also things like superchips, that plugs in and gives you more horesepower. Now my question is there any company or product that does both? both gives you more HP, and gives your speedomoter adjustments for larger tires?
Old Dec 4, 2004 | 11:03 AM
M3Man02's Avatar
Come on somebody has to know....................????????????????????
Old Dec 4, 2004 | 12:41 PM
Flamedx4's Avatar
Maybe, but I doubt it. Most of the programmers need to know if you've changed tire size, but speedo recal is a different thing and probably not part of the programmer, since you'd have to interup the wires to the speedo and insert the compensator. Go to their websites and read their stuff.
Old Dec 6, 2004 | 07:48 AM
Yamaha+Toyota=Fun's Avatar
You could also regear to fix you spedo readings.
Old Dec 6, 2004 | 07:55 AM
SLC Punk's Avatar
There are devices to reprogram the ECU for more performance and tire size changes. Unfortunately, it does not work for Toyota's because their ECU's cannot be reprogramed.
I have read that the piggy-back chips do not add the performance that is advertised.
Old Dec 6, 2004 | 08:47 AM
Flamedx4's Avatar
Make that "You SHOULD also regear to fix you speedo readings..."
Old Dec 6, 2004 | 10:19 AM
Flygtenstein's Avatar
Precision and Yukon sell products that reset the speedo to match bigger tires and add HP to compensate.
djpg2000
Nov 11, 2020 04:56 AM
jgallo1
Oct 26, 2015 06:39 PM
coffey50
Jul 28, 2015 10:55 AM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
Yotoder865
Jul 9, 2015 07:51 PM
