ES shock bushings?
Old Apr 14, 2003 | 03:30 PM
rabidbeaverbaby's Avatar
ES shock bushings?
does Energy Suspension make replacements for the bushings on top of the front shocks? and does anyone know the part numbers for these? thanks a lot....
Old Apr 14, 2003 | 05:03 PM
Firefyter-Emt's Avatar
You can use sway bar bushings.. They are the same diameter and fit exactly the same as the stock bushings.. That is what I did with a set I had bought for all those quick disconnects...
Hey, if you want to buy a set really cheap let me know... I bid on a set of black ones off e-bay and they are not Energy Suspension bushings and are slightly taller.. They would work for the sway bar links, but I would have to change the measurements.. Here is what they look like..
Just so that you know, the washers under the bushing washer is to space the shocks down for the low profile bump stops..
Shoot me an e-mail.. I have 4 bushings and whashers that would work perfect..
ladybugRC
458
Aug 21, 2020 10:41 AM
ZGjethro
Jun 7, 2017 11:04 PM
live4soccer7
May 11, 2016 06:52 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
ktm192k
Oct 1, 2015 08:47 AM
