engine trouble
Old Sep 12, 2004 | 10:56 AM
desert whomper's Avatar
engine trouble
my 22re, when around 1500 rpms, its an estimation as i have no tach yet, starts to die or sputter then goes back to 1500 rpms then stays there for a few seconds then sputters to lower rpms and then revs back up. is there a bad vacum somewhere? a valve stuck or something. im confused.
Old Sep 12, 2004 | 11:07 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
When was the last time you changed your fuel filter? Sounds a bit like fuel starvation...
Old Sep 12, 2004 | 09:55 PM
who know, just bought the truck 2 weeks ago and still making sure everything is fine, but i look into it
Old Sep 13, 2004 | 04:16 AM
HondaTec521's Avatar
Check you tps !
Old Sep 13, 2004 | 07:02 AM
colsoncj's Avatar
See if its throwing an engine code. mine did that a while ago, it was throwing a tps idle setting code, or something like that. i had to adjust the tps on the throttle body (also cleaned the throttle body while i was there), and that took care of the problem.
mskalmus
May 28, 2017 07:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
cyclist231
Jul 7, 2015 12:56 PM
elwood73
Jul 5, 2015 07:07 AM
