engine knocking after rollover
Old Jul 22, 2012 | 02:20 PM
beeznoots's Avatar
I rolled, or I should probably say flipped my '04 Tacoma. It was upside down for about an hour. After replacing fluids I tried to start. It shook hard but started. Once running there is a loud knock noise coming from the engine. Its a steady knock knock knock that seems to match the rpms. After starting it, of course, I looked at this forum an realized I probably should have pulled the plugs first. I hope I didn't screw anything up. I then replaced the plugs but the knock is still there. Any ideas what the knock might be?
Old Jul 22, 2012 | 03:42 PM
rworegon's Avatar
Are you sure the sound is coming from the engine and not something pushed into the fan? If engine, from the upper or lower part?
Old Jul 22, 2012 | 03:51 PM
beeznoots's Avatar
I can't see anything wrong with the fan. It doesn't seem to be hitting the housing and nothing seems to be jammed into the blades. The only visible damage is on one side and the cab is crushed in. The hood was completely untouched and everything under seems to be in place. The noise is loud enough its hard to tell where exactly its coming from but it seems to be the upper part.
Also, there was quite a bit of oil on the plugs when I pulled them out, as well as everywhere else under the hood. I put new ones in but didn't exactly clean anything out. Could it be as simple as one of the new plugs not firing?
Old Jul 22, 2012 | 05:05 PM
rworegon's Avatar
Up top - valves, down below - piston connecting rods that possibly bent when you fired up the engine with something in the cylinder (oil/water).
Old Jul 22, 2012 | 09:02 PM
vital22re's Avatar
totally a bro
You bent a rod by not pulling the spark plugs and clearing the cylinders after the roll. You're looking at a full tear down or just a replacement motor.
Old Jul 22, 2012 | 09:15 PM
streetlancer's Avatar
Pics?
Old Jul 23, 2012 | 11:07 AM
westjohns yota's Avatar
there was a double cab rolled a few days ago here in pensacola? was that you??? and on its side so i should say, and yeah u bent the road and or broke it
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
smiley52
Jul 11, 2015 05:16 AM
