Engine Bay Cleaning
Old May 1, 2004 | 03:42 PM
Scofco's Avatar
Engine Bay Cleaning
I am just about to head down and simple green my engine bay, couple quams first.
I have seen people using pressure washers on their engines, without covering anything up, then driving off. WTF? I thought this was a big no-no.
I'll also be using a pressure washer (standing far away) for mine right now, will that be okay?
What should I be covering up? With what? Tinfoil?
Old May 1, 2004 | 03:48 PM
ilion's Avatar
Battery? (though obviously not with aluminum foil)
Fuse box?
Distributor?
Alternator?
My girlfriend's Uncles are Mechanics and one of them refuses to use a pressure washer to clean engines... In his words, "...it crams water where it's not supposed to go."
I can't see much harm in 'low-pressure washing,' as in, garden hose pressure, but again, I've no idea what I'm talking about.
^_^
Old May 1, 2004 | 03:50 PM
Scofco's Avatar
Standing far away, as in misting the engine for awhile until it's rised, not diving right in there with the high pressure part.
I get free car washes, so time isn't a worry with the pressure hose
Old May 1, 2004 | 04:00 PM
ilion's Avatar
Seriously, just go to the fire station and ask them to hose down your engine compartment for a bit.
Sure it might take the head(s) off, but it'll be CLEAN inside!
^_^
Old May 1, 2004 | 04:08 PM
Designsbyme's Avatar
You shouldn't wash your engine in cold weather and drive off. If the climate is warm you've nothing to worry about. Make sure your distributor cap is tight so you don't get water in it. Avoid the battery. You should be fine otherwise.
Old May 1, 2004 | 04:15 PM
Bob_98SR5's Avatar
scofco,
i covered all the fuse boxes, alternator, drive belts and battery. thats all. i used a hose at low pressure to rinse off.
bob
Old May 1, 2004 | 04:16 PM
Scofco's Avatar
What do you cover it with?
I've opted to use the garden hose
Just means I'll have to go and buy one tonight then.
Old May 1, 2004 | 04:41 PM
RED 85's Avatar
Just Had my friend work on my wife's Durango and he steamed cleaned the engine with a pressure washer and had no problem with it. He is a lead tech and a dealership.
I have always washed my engines with a pressure washer and never covered up anything and not one problem has came from it.
Old May 1, 2004 | 04:46 PM
george16's Avatar
I use regular plastic grocery bags in covering up the fuse box, battery and alternator. I've been using simple green for a long time and just use a garden hose to rinse it off. So far no problems. soak the engine bay with simple green for about 5 mins and rinse away.
George
Old May 1, 2004 | 05:12 PM
Scofco's Avatar
I've opted to just not cover anything and then let it sit for a few hours, should be okay that way eh?
Old May 1, 2004 | 05:13 PM
Scofco's Avatar
Here is the before:
Old May 1, 2004 | 05:14 PM
rimpainter.com's Avatar
I never cover anything on mine. I just let her rip! No problems.
(Aim carefully though)
Old May 1, 2004 | 05:45 PM
Scofco's Avatar
The After:
Old May 1, 2004 | 06:37 PM
My99's Avatar
Looks good! Did you use a brush or any scrubbing, or was it just the simple green and a hose? My only complaint with simple green is that it leaves a white pastey substance on stuff it seems.
Old May 1, 2004 | 07:05 PM
Amkeer's Avatar
I hose the engine off once a month and dress it with a silicone once dry. (pics in the website or sig)
Here is what to do:
Start engine and idle for about 2 minutes.
Shut off engine and spray dawn and water mixture from spray bottle on engine components. 2 tblsp to a quart.
Let mixture sit for 5-10 minutes.
Spray off engine with fan setting on nozzle.
Repeat application of Dawn and brush with parts washer brush any stubborn areas.
Rinse.
Start engine and let idle for 5-10 minutes.
Take vehicle for a 15 minute ride to displace any remaining moisture.
Once engine is cool apply silicone dressing.
Note: Never hose off a HOT motor!!!!!!
Old May 1, 2004 | 07:29 PM
kernel's Avatar
I've cleaned several hundred engines and the only problems I've ever had were with Fords. GM, Toyota, no problem. Engine degreaser and blast away.
Old May 1, 2004 | 07:31 PM
bike4miles's Avatar
Yea, same hear. No problems. just don't hit the elctrical stuff at close rage and shoot selectively and it's no big deal.
Old May 1, 2004 | 08:54 PM
User 051420's Avatar
I always just head to the carwash and spray on the degreser, wait..wait wait.. And then blow it all off with the high pressure. NO covering anything, no problems yet.
Old May 1, 2004 | 09:00 PM
Scofco's Avatar
The engine stumbled a bit just now on the way home, and it was idling at 500 for some reason. Hopefully that will go away
Old May 1, 2004 | 09:31 PM
BT17R's Avatar
Here is what to do:
Rinse.
You won't find a better, safer, more effective method than this. It's the same MO I've used on vehicles for years with no ill effects. I switched to this after drowning a Mercedes ECU on a car I had for sale. Killed it, and the profit potential, with a pressure wash on that one, but I considered it a seminar expense.
