Electrical Question
Electrical Question
I have some auxiliary lighting to wire up. Wiring it up looks to be fairly easy however I don't care for the switch provided with the kit. FUGLY.
I bought one that I like from Radio Shack that look a lot cleaner and the light will match the dash lights better. However it's rated for 25A at 12VDC. I noticed this after the fact, n00b. The switch that came with the kit, Hella Black Magics, is rated at 30A at 12VDC. Yes to be safe I should get a 30A switch but will the 25A switch work just fine?
Originally Posted by eric-the-red
Ideally you should wire the lights with a relay, and then there is less than 1A going through the switch.
As you can tell I'm new to this stuff but the instructions look easy enough to follow.
Co-Founder/Administrator
A little info on wiring up extra lights.
https://www.yotatech.com/~corey/tech...ghts/corey.htm
Ditch the Hella switch too, and go to your Toyota dealer and get the switch in the write-up.
It fits Toyota dash cutouts.
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
v_man
Jul 23, 2015 04:01 PM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
Jul 8, 2015 07:15 PM
