ECT Power/Norm Button
Old Mar 5, 2007 | 09:45 AM
midiwall's Avatar
Originally Posted by Tacoclimber
I wish!
Ah, someday maybe...someday. But then again, I'm already pushing the speed limits in the truck the way it is... I'd be in serious trouble with a S/C!
Oh now CJ, you knwo it's not about SPEED, it's "just" POWER.
heh.
Old Mar 5, 2007 | 09:59 AM
91TPU's Avatar
Originally Posted by pat161
This is the info I was correcting, which clearly says it holds a higher gear longer. And I disagree, part of ECT power is it will downshift sooner.
Please read my thread and others before you try to correct me, I know exactly what the button does.
haha i didnt even realize that i swapped higher and lower..oh well i got the jist along...im running on 2 hours of sleep, drove 100 miles this morning and wrote a 7 page paper before class which was at 10...i made a mistake
Old Mar 5, 2007 | 10:01 AM
Tacoclimber's Avatar
heh.
Riiiiight....
Old Mar 5, 2007 | 10:20 AM
Tanto's Avatar
... It especially useful now that I'm running 285's on 4:10's...
You may want to double-check your gearing...mine has 4.30
Old Mar 5, 2007 | 11:59 AM
  #25
surf4runner's Avatar
Originally Posted by Beartracker
Some guys like to drive around with the button on all the time but it's not for that and it will make your truck use more gas in the long run, Mike
ive been driving with it on for over a year and still avg 20mpg.
it doesnt downshift any sooner with it on(same RPM's actually), only stays in the lower gear longer before shifting up(like most agreed)
i drive over a significant grade 2x daily, so ive had many chances to test it.
Old Mar 5, 2007 | 12:27 PM
  #26
Oh suure... Just rub it in...
So when are you going S/C there, Long Travel Tanto?
Old Mar 5, 2007 | 05:32 PM
  #27
RETRO's Avatar
Thanks Guys I tried it out today I could not tell any difference when I pused it on.....
Old Mar 5, 2007 | 06:58 PM
  #28
MARSHALLMAY's Avatar
the button doesn't make your engine have more power. It merely lets the engine rev higher between shifts and makes the tranny downshift at lighter throttle. I've noticed that it helps in demanding traffic. If I have to speed up really quick to keep someone from cutting me off and my ect button is off, I hit the gas and the transmission doesn't allow a quick extreme downshift. With the button on, in a split second, the tranny releases the current gear, lets the engine rev up and grab a lower gear with the rpms right in the middle of the power band. As for downshifting, I notice the biggest difference while using cruise. While motoring up a hill with ect off, the computer will wait longer for and for a heavier load to build on the tranny to downshift and causes a downshift jolt. With ect on in the same situation the tranny downshifts under a lighter load, readying the engine for more power demand before it starts losing rpms on the climb. If you never press the gas past half way, you probably won't be able to tell if ect is on or off.
Old Mar 5, 2007 | 07:04 PM
  #29
rimpainter.com's Avatar
Just get a 5-speed; you won't have to worry about all these buttons.
Old Mar 5, 2007 | 07:36 PM
  #30
X-AWDriver's Avatar
Ahhhhh,so true.
Old Mar 6, 2007 | 03:48 AM
  #31
xcmountain80's Avatar
Exactly!!
Old Mar 6, 2007 | 05:11 AM
  #32
pat161's Avatar
Right, it will stay in 3rd (which is higher than 2nd) longer before shifting to OD.
Wow... So, you're going from "I was under the impression..." to "My word is golden, do not correct me".
Okie doke.
I'll just chalk this little attack up to a misunderstanding. You have twisted my words so much I have no reply. If you actually read my first post and the one I was responding to you will see that your correction is totally out of line. But if trying to make me look bad makes you feel better, then so be it.
Old Mar 6, 2007 | 03:43 PM
  #33
RETRO's Avatar
Man I am so tired of changing gears..This is my first truck that is auto,after 21 years of driving it's time...I will miss the manual when I am on the trails..
Old Mar 6, 2007 | 04:30 PM
  #34
I love my 5-speed, but actually find myself wanting an AT every now and then. Go figure.
Old Mar 7, 2007 | 06:31 AM
  #35
I suppose it's true then: "the grass is always greener..."
I do miss the 5 speed when I'm wheeling. On the road...not so much.
Longbed 90
Mar 11, 2019 12:38 PM
Longbed 90
Oct 19, 2015 11:05 AM
Boomer8404
Sep 20, 2015 06:15 PM
VT2LAB
Sep 10, 2015 09:36 AM
Highlander Giant
Sep 8, 2015 06:46 PM
