E-locker inquiry
Old Nov 10, 2009 | 07:02 AM
SafariRNR's Avatar
So do I need to get a new e-locker computer for mine and leave my wife's in place? Or can I just swap computers with her and her ABS will work? Does it actually disable the ABS or just make the light come on? Myself I wouldn't mind not having ABS. This is getting a little more confusing than I thought it would be.........
turboboost- It's actually surprisingly clean, go figure!
Old Nov 10, 2009 | 07:27 AM
WD_40's Avatar
Others will have to weigh in on the computer swap (I don't know the answer on that one), but if it ends up that you can't swap computers then use the inchworm wiring kit HERE. I guarantee you won't be getting a new computer for less than $75.
Old Nov 10, 2009 | 09:39 AM
SafariRNR's Avatar
No offense but for $75 that kit kinda seems like a rip off. I pretty much have all those items lying around my garage. I'm sure I could just hook up wires to the locker and make it work but i'd like to try the factory option first. If nothing else for the 5mph saftey.
Old Nov 10, 2009 | 10:28 AM
theferg's Avatar
My initial thought is that since both your 4Runners are '98, you could just swap the 4wd computers. I'm not sure on that, but maybe have a gander at them and see what you think. Post up some pics and part numbers if you're unsure. I'd bet you could just swap them between the two vehicles without a worry.
Originally Posted by KZN185W
There are 4 types of 4WD computer on the VZNL/RZN185L 4Runners. Only one of the four is for the one with e-locker. Have you tried using the 2002 computer on the 1999?
So if you're wired for e-locker, then you're wired for e-locker (or partially wired in some cases), and if you didn't actually *get* the e-locker, you got a different 4wd computer that just ignores some of the connected wiring. Correct? So turboboost should have pretty good chances with switching his two around as they're both '98s.
-Ferg-
Old Nov 10, 2009 | 11:08 AM
  #25
bob200587's Avatar
Originally Posted by brian2sun
Not only would it be easier, but I don't think you have a choice but to swap entire axles cuz if you just swap 3rds, I don't think you'll be able to put your non-elocker 3rd in your wife's axle housing since it has the cut-out for the elocker motor. And like Elton said, make sure the ring and pinions are the same ratio.
This.
you'll have to swap the whole thing from..."flange to flange", I guess that's what it'd be called on the rear.
Old Nov 10, 2009 | 12:14 PM
  #26
SafariRNR's Avatar
I already figured on switching the whole rear axle. Thus why I checked the build codes. As far as computer for computer, since they are the same year and exact same build code, I am hoping so. I'll look at the wiring when I get a chance and try to figure it out. Just out of curiosity, if you are fully wired should there just be an empty plug hanging by the diff? How many people have been so lucky anyway?
Old Nov 10, 2009 | 12:38 PM
  #27
theferg's Avatar
I asked a similar question a few posts back...
Originally Posted by theferg
So, on the "pre-wired" 4runners/Tacos, is there some sort of a terminator connector that is connected to the e-lock ECU wiring harness? If so, anybody have one they want to get rid of or anybody have a part number?
So from this, I gather the answer to your question is no. If you're pre-wired for locker, but don't have the locker, then you have a different 4wd computer and the harness is still connected to it. Thus, you should be able to just swap computers between your two 4Runners.
I think I'm getting this...please correct me if I'm not.
And FWIW, my '02 has a completely different 4wd computer and and a completely different connector/harness.
-Ferg-
Old Nov 11, 2009 | 07:15 AM
  #28
SafariRNR's Avatar
Well it rained all day yesterday after I got home so no snooping around. Maybe i'll look today if weather permits.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
1uzRunner
63
Nov 10, 2018 03:58 PM
Patrick1976
Sep 15, 2015 11:33 PM
zz_denis
Sep 6, 2015 03:43 PM
AaronM
Jul 8, 2015 07:15 PM
