Driver Footwell Click
Old Aug 30, 2008 | 08:01 PM
MunkeyTX's Avatar
Howdy guys,
Recently, I've noticed a clicking noise coming from the drivers footwell, specifically right behind the clutch/far left footrest area. It sounds exactly like a relay clicking, and it happens when I use the clutch, sometimes over bumps, and if I get on or let off the gas pedal quickly; I'm thinking its happening when the body slightly flexes on the frame, maybe a broken spot weld??
Not really a immediate problem, but it is kinda annoying.
Just wondering if this has come up with a simple fix before.
Thanks!
Old Aug 30, 2008 | 08:52 PM
BigBallsMcFalls's Avatar
blinker fluid is low
Old Aug 30, 2008 | 08:54 PM
MunkeyTX's Avatar
Intelligent Donkey You Are!
Mmm, crap, I forgot about that! Guess I should check the muffler bearings too??
Old Aug 30, 2008 | 09:04 PM
Godzilla's Avatar
These members report a squeaking, however it may be related.
https://www.yotatech.com/forums/f2/f...bushing-19137/
Old Aug 30, 2008 | 09:06 PM
Godzilla's Avatar
Here ya go,..most likely the bushings or the spring
https://www.yotatech.com/forums/f2/9...eaking-134929/
Old Aug 31, 2008 | 12:52 AM
scuba's Avatar
x2 on the blinker fluid, i would check that first
Old Jan 14, 2009 | 10:37 PM
idanity's Avatar
i would check the welds and the master cylinder shaft..
this is mine 2 days ago.
hope that helps
happy trails
bvleonov
Aug 22, 2015 11:39 PM
94yotaky
Jul 23, 2015 07:50 AM
coryc85
Jul 6, 2015 04:07 AM
