Drive shaft vibration
Old Feb 24, 2004 | 06:17 AM
obxfishn's Avatar
I had a 3" lift put on my 02 Taco and now I am getting a vibrating feeling when my truck is decelerating to about 25mph. I think it might be my drive shaft going to the rear diff. Is this caused by the angle of the drive shaft? If it is how would I correct the angle to eliminate the vibrations. I have had an alignment and I cannot think of any other reason for the vibrations other than drive shaft angles. Any help would be most appreciative.
Old Feb 24, 2004 | 06:22 AM
99TRDTaco's Avatar
I am having the same problem so hopefully someone will help us out.
Old Feb 24, 2004 | 06:23 AM
Mad Chemist's Avatar
Did you install a diff spacer along with the lift? Do you see much grease splatter coming out of your CV boots?
Old Feb 24, 2004 | 06:35 AM
99TRDTaco's Avatar
I have a prerunner so no I did not install a diff drop. I am pretty sure it is comong from the rear.
Old Feb 24, 2004 | 06:40 AM
BruceTS's Avatar
did you try lubricating the driveshaft?
Old Feb 24, 2004 | 06:55 AM
obxfishn's Avatar
I do have a diff drop kit installed and I did grease the drive shaft very well. I have not noticed any grease splatter coming from the cv boots.
Old Feb 24, 2004 | 07:03 AM
GRNTACO's Avatar
You may have to shim the the rear to get the proper pinion angle. http://www.4x4wire.com/toyota/tech/driveline/
88sasturbotoy
Jan 30, 2026 01:57 PM
jasonty
41
Dec 23, 2018 01:00 PM
A2theK
Jan 10, 2016 10:18 AM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
