Does zip-tie installation of Hayden tranny coolers really case damage?
Old Feb 20, 2005 | 05:39 PM
argonzero's Avatar
Hello there,
Tons of stuff on this board about the hayden 1678 cooler, but i was wondering is it really true the ziptie would eventually rub so much as to cause damage? There was one person who brought it up in a thread, but im not certain theres any truth to it. I just figure the zip tie would wear out before the metal tubes on the radiator does (the fins might break, but who cares about the fins).
Old Feb 20, 2005 | 05:50 PM
argonzero's Avatar
I just had a thought, the guy at the Pepboys did bring up an install kit which is just the mounting hardware normally included with the cooler. So maybe you could just use 4 extra zip ties and pads in order to distribute the load more evenly. Just a thought.
Has anyone actually made their own brackets to mount like the TRD brackets? I seen the underbody mounts, but they seem dangerous to me.
Old Feb 20, 2005 | 05:58 PM
WT's Avatar
WT
Originally Posted by argonzero
Hello there,
I ended up mounting mine from the frame at 2 spots that already had holes, I just had to enlarge 2 holes on the cooler, see photos in the album..
http://community.webshots.com/photo/...27130376YWrBsV
MTL_4runner's Avatar
I think the zip ties have foam pad on them to prevent the rubbing...mine did anyway.
The part going through the radiator is in tension so I doubt it will have much chance to rub.
Old Feb 21, 2005 | 08:03 AM
Marc's Avatar
For what it's worth the guy at my rad shop says the zip ties work fine as long as you use the pads to protect the rad/cooler/condensor.
Old Feb 21, 2005 | 09:32 AM
Also try to snug the ties straps as tight as possible to compress the foam padding, the padding will take a set and loose compression later.
I have had Haydens on some customers vehicles now for close to 6 yrs with no problems.
Old Feb 21, 2005 | 02:41 PM
Sparman's Avatar
I used stanless standoffs to mount mine. One end is 1/4-20 female and the other is 1/4-20 male stud. I used button heads and nylok nuts. They fit in the existing holes on the crossmember and only required a 1/4" hole to be drilled into the flange on the cooler. Nice and secure and independent of a/c condenser. You can find all the hardware at mcmaster carr.
Attached Thumbnails Does zip-tie installation of Hayden tranny coolers really case damage?-tranny-cooler-small.jpg
Old Feb 21, 2005 | 03:09 PM
Jeffires's Avatar
I put mine on with the included zip ties and foam about 5 years ago and have had no trouble.
Old Feb 21, 2005 | 04:14 PM
4-RUNNIN' FREAK's Avatar
LORD mounts
http://www.pegasusautoracing.com/gro...ID=HARDVIBRATE
Maybe someone has a size similar. I don't have the instructions for the TRD tranny cooler so I can't cross reference the sizes needed.
Old Feb 21, 2005 | 05:30 PM
bikeguy18974's Avatar
I don't have a hayden but a similar model. It came with mounting brackets that are nothing more than pieces of flat steel with a few holes drilled in each end. You can buy the same type of thing at home depot in numerous sizes. I put one of each bracket on the radiator mount, and the other on the cooler. Its hard mounted at all four corners and doesn't move at all. I have a body lift so I had longer bolts to use from my radiator drop brackets but with longer radiator mounts bolts you should be fine.
Old Feb 21, 2005 | 11:42 PM
You could always buy an Earls Performance cooler, while they are more expensive they are thicker and more efficient than Haydens or similar stacked plate coolers.
Earls has a mounting kit for most of them and they come in a variety of different size pipe or AN fittings.
I have a 13 row Earls on my 2nd gen, no pics handy right now but some old timers may remember it.
This is a 24 or 25 row Earls on my car but shows the mounting kit for it. Each of the upper and lower aluminum brackets have foam padding next to the cooler.
BeMiceElf
Oct 10, 2015 09:40 PM
Iceman4193
Jul 15, 2015 04:48 PM
Coreyr384
Jul 10, 2015 11:13 AM
crashburnoveride
Jul 10, 2015 06:39 AM
Snort
Jul 9, 2015 03:58 PM
