Do i need to change fluids?
Old Oct 21, 2002 | 06:39 PM
914runner's Avatar
I have a 1991 4runner V6 manual 4wd and it has a little over 200,000. Im wondering if i should change the diff and transfer case fluid, it hasnt been done for at lease 100,000 if at all. So if i do i was thinking about running amsoil, but i dont know what weights to run, how many quarts i will need and what tools and parts i will need to takle this task at home.
Thanks
Old Oct 21, 2002 | 06:59 PM
CTB's Avatar
CTB
Yes, definitely change those fluids if it has been that long since they were last changed.
I believe you should use 75-w90 gear oil in the front diff, rear diff, and transfer case. However, check in your owners manual and it will say for sure. The owners manual will also tell you fluid capacities.
All you are going to need is a wrench and some sockets.
Just remember - always open the fill plug first so that you are sure you will be able to refill once you open the drain plug!!!
Old Oct 21, 2002 | 07:13 PM
914runner's Avatar
i dont have the owners manual. but does anyone know how many quarts i will need?
Thanks for the help!
Old Oct 21, 2002 | 07:34 PM
Corey's Avatar
Co-Founder/Administrator
Fresh from Corey's scanner
http://www.pnw4runners.net/tech/fluids/
Old Oct 21, 2002 | 07:52 PM
Robinhood150's Avatar
Checkout this post.
Steve
Old Oct 21, 2002 | 07:57 PM
914runner's Avatar
corey that helped a ton thanks.
Thanks to everyone else too.
Old Feb 22, 2015 | 09:23 AM
Operation4Skinner1.5's Avatar
Yes! Please change your fluids!
Old Feb 22, 2015 | 09:46 AM
Roark's Avatar
Whaaaaat
Old Mar 8, 2015 | 11:25 AM
914runner's Avatar
Wow, my 12 plus year old thread lives again!
Old Mar 11, 2015 | 09:58 AM
lekiboy's Avatar
Links are no longer working though.... Any chane of a link with part numbers for usual items to replace? Tnx
jasonty
41
Dec 23, 2018 01:00 PM
Up&Down
Aug 11, 2015 10:04 AM
Poppie51
Aug 2, 2015 11:29 PM
rchavis
Jul 27, 2015 07:41 AM
the1998sr5
Jul 16, 2015 06:20 AM
