Diagnostics problem
Old Oct 2, 2007 | 06:49 AM
Gator's Avatar
Don't take this the wrong way, but did you double check the gap on the new plugs before installing them?
Also, when doing a compression test, all plugs need to be out to accurately gauge the compression on a single cylinder.
Old Mar 15, 2011 | 07:37 PM
mick cassidy's Avatar
Can any one tell me the location of the obd port on my 91 v6 ?? got to find the source of the "check engine " is this obd 1 or 2 so i know what scanner to get /thanks
Old Mar 16, 2011 | 03:48 AM
mt_goat's Avatar
It's OBDI, all you need is a paper clip to pull the codes. I can't remember which pins to bridge with the paper clip, but its around here somewhere. Good luck
EDIT: Here it is: http://personal.utulsa.edu/~nathan-b...85diagnosi.pdf
Liadrin
Apr 25, 2022 02:54 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
Sandman
Jul 14, 2015 12:36 PM
