Depressurizing fuel system
Old Sep 16, 2004 | 09:08 AM
VORTMAX_99's Avatar
Going to change fuel filter on my 99 Tacoma 2.7l 4 cylinder.
Am debating on best way to depressurize the fuel system.
Looks like there's the main EFI relay in the engine bay
as well as a 15 amp fuse that says EFI. Also I believe
you can pull the circuit opening relay that's located
under the dash. I'm leaning towards either the relay
or the fuse in the engine bay as it's easier to access.
Any one have any pro's or con's on using either?
Thanks for any info,
Geo.
Old Sep 16, 2004 | 11:44 AM
Maddog's Avatar
I spent awhile trying to find how to do this when i did mine,but after mucking around for 1/2 an hour ,i just undid the fuel cap.i only hade a very very small amout of leakage.when i un do my fuel cap it makes a nice "tsish" sound so i know it relesing some pressure.
Old Sep 16, 2004 | 12:59 PM
BeaterToyota's Avatar
When I did mine on my '88, I just unplugged the wiring harness for the pump right near the gas tank. Turned the key and cranked the engine over once or twice and everythng was cool. I don't know if that's the right way to do it, but I've done it twice with no bad side effects.
Old Sep 17, 2004 | 10:34 PM
SlimJim248@earthlink's Avatar
The manual for my 85 says to start the car and pull the harness from the pump and just let it die. Seems to work well.
Old Sep 19, 2004 | 02:20 PM
pfdaxe's Avatar
I did it this same way on my '00. I just loosened the gas cap and a very, very small amount dripped out of the filter when removing. The whole filter change start to finish was about 10 mins.
Old Sep 19, 2004 | 02:28 PM
88-4RUNA's Avatar
remove the fuse, start it wait til dies. Then stick a screw driver in the gas filler slot.
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Fundy Rider
Jul 16, 2015 01:35 AM
shisha1999
Jul 13, 2015 11:09 PM
