deep water
Old Jan 9, 2004 | 12:23 PM
FirstToy's Avatar
Originally posted by mt_goat
Mine rear breather goes up to the bottom of my bed and then hangs down about 4 inches, that will let any spray drain out. My front breather goes up next to the battery. I guess you could run the rear tube up front, hose is cheap.
If I did that, the breather would be at the same or lower location than stock.
Routing to the front sounds good. maybe when I decide to change that again I'll put it with the others in the engine bay...
Old Jan 9, 2004 | 12:33 PM
4x4CPOSEADOG's Avatar
Wow! Good write-up by WATRD. Good Job! Now, do you have any write up for the front differential? How do you guys extend the breather on the front diff? Any idea?
Noel
Old Jan 9, 2004 | 01:00 PM
WATRD's Avatar
Noel
The front is really easy. This from a Tacoma, so you mileage may vary.
The front diff breather is already extended and is mounted on the inside of the drivers side fender, about half way up the wheel well indentation. It's high enough for moderate use where the water level doesn't get higher than your door sills or so. If you want to extend it, just add some hose to the existing set up with a double barbed connector and a couple of hose clamps.
presto30
Sep 15, 2015 09:41 AM
LotOMiles
Sep 14, 2015 11:45 PM
elaketiger
Sep 14, 2015 09:58 AM
--Oz--
Sep 6, 2015 01:06 AM
