Deck Plate Alternative?
Old Dec 29, 2004 | 08:25 PM
calrockx's Avatar
yeah, you could just leave the top open, but that seems like a temporary, half finished way of doing the more air mod. the deck plate is permanent, reversible (well, in effect anyway), cooler, keeps the filter secure, plus it gives you a chance to get in some quick wrenchin and get to know your ride a bit more.
and if you want the full noise fury of the 3.4, go internal snorkel.
Old Dec 29, 2004 | 08:56 PM
kevin444's Avatar
I can also sell you an isr kit. plug and play!
Old Dec 29, 2004 | 09:06 PM
boogyman's Avatar
Talking
Originally Posted by <96 Runner>
The problem with leaving the flap open is that it serves a purpose other than air filter access; it also holds the air filter securely. By removing the flap, you are also removing an important aspect of proper filtration. Don't get me wrong, I have removed the flap on my old Tacoma - but nothing beats the functionality of a properly installed deckplate.
As a temporary sound mod, I would say it is ok. But I would do the deckplate mod ASAP. And I would never off-road with the flap open.
Part of the deckplate's dyno-proven 5HP is due to the air being rammed in from the front. With the flap open, you are most likely pulling in warmer air and you lose the ram effect. Some things to think about.
Old Dec 29, 2004 | 09:09 PM
boogyman's Avatar
Talking
Originally Posted by TACOMANATOR
Hence the imporatance of the c-clamp to hold the filter against the airbox. While your moving there really is no hot air in the engine compartment. If you pulled out the headlight and some other things I could see the "ram air effect". But with all that stuff in the way I doubt there is a difference. I cleaned my throttle body two weeks ago and there was no dirt or dust at all in the intake tubing after a year.
here's a good reason to do the deckplate instead of removing the top of the airbox and using a c-clamp:
what happens when you want to make a water crossing? all you have to do is screw in the deckplate to close everything up. If you take the top off, then you have to remove the c-clamp and replace the top of the airbox. Seems to me like the deckplate is more work at the beginning, but easier in the long run. just my opinion though..
-Russell
Old Dec 30, 2004 | 11:24 AM
  #25
BruceTS's Avatar
Just remove the elbow off the air box........ that's the easiest.
For me the deckplate was the proper choice, as mentioned already, it's far easier to screw in the plug, rather than trying to re-fit the top cover.
Old Dec 30, 2004 | 08:34 PM
  #26
dibble9012's Avatar
Today I drove around all day without the airbox cover on. First I tried the C-Clamp, and was worried that it would fall off, so instead I drilled a hole in the frame of the filter, and the airbox, then used a plastic tie to hold it in place. I did feel some improvement in acceleration(felt like I had ECT on) and I did hear some extra noise. Will doing the deckplate mod improve performance even better? I did hear more noise than usual, how much of a noise increase do most of you get? (I want more noise, hahaha)
Old Dec 30, 2004 | 08:47 PM
  #27
jimstoy's Avatar
My air box has the bottom cut out of it. Seems ok. Have creeped into some deep and long water holes. Lucky so far. I need to up grade.
jim
Old Dec 31, 2004 | 06:33 AM
  #28
98LimitedCustomized's Avatar
I opted to get rid of that whole ugly black intake setup, and got an Injen intake..... it's a loud, probably similar to the deckplate mod... performance gains are small.... or hard to tell cause I put on bigger tires the same time I did the intake.
Old Dec 31, 2004 | 06:35 AM
  #29
rimpainter.com's Avatar
If you want loud, the deckplate mod and ISR mod are your tickets.
Old Dec 31, 2004 | 07:00 AM
  #30
X-AWDriver's Avatar
Removing the lid looks kinda ghetto IMO and the deckplate can look stock to the casual observer if even noticed plus like stated above you can seal the box back up in a matter of seconds.
Old Dec 31, 2004 | 10:04 AM
  #31
4-RUNNIN' FREAK's Avatar
I drove with mine open for a little bit. Can't really hear it over the S/C whine anyway. You have to have the hood open and know what to listen for and you can hear it. The only thing I noticed was worse MPG. Not much of anything else. Now stays shut. I will try it in the summer months tho and see what it does as this leads to the fact that I did it in late November to early December. I haven't posted for some time until today, and I have lost the records I kept of the MPG in my recent upheaval.
Old Dec 31, 2004 | 11:32 AM
  #32
dibble9012's Avatar
I would be very interested in your kit, can you send me pictures of the kit? I will probably do this mod soon, just need to figure out some things, like if I need to use premium gas to prevent pinging. Thanks
Old Dec 31, 2004 | 01:51 PM
  #33
Adam F's Avatar
Sheesh, just do the deckplate mod already! It's SUPER simple. No worries, you can simply seal it back up at any time.
Why monkey around with clamps and all that ghetto shiznit? Just cough up about $20 and do it already!
Old Dec 31, 2004 | 03:07 PM
  #34
dibble9012's Avatar
yea, i am doing it, just wanted to feel/hear it before i actually did it. I can definitely feel it, and the sound is just great, so great that I am doing the Intake silencer mod too.
Old Jan 1, 2005 | 06:58 AM
  #35
TACOMANATOR's Avatar
And hacking a hole in your airbox and installing a boat deckplate on a car is less ghetto. It takes about 10 seconds to remove the clamp and snap the lid back on. Besides it's reversible.
Old Jan 1, 2005 | 12:03 PM
  #36
X-AWDriver's Avatar
Removing and installing the stock lid will eventually compromise the stock seal since that lid will just become looser and looser the more you swap it on and off guaranteed.
I think I can spend $15 and spend an hour doing a professional looking mod while retaining the factory look and sealing qualities of the stock airbox lid,a deckplate isn't even noticed by emissions inspectors.
Old Jan 1, 2005 | 12:18 PM
  #37
I have yet to put the lid back on in one year. I don't know of any water crossings in Colorado that I would have to worry about. Removing the lid is a good alternative for those who don't want to cut a hole in their airbox.
Old Jan 1, 2005 | 12:26 PM
  #38
X-AWDriver's Avatar
Yeah,how many of us deckplate guys actually put the plate back in. I had a deckplate in my '97 for over a year and not once put the plate back in.
Old Jan 1, 2005 | 12:34 PM
  #39
FilthyRich's Avatar
it all depends on how much H2O you drive through and how deep. it's nice to close the hole. with all the mods most of us do anyways, does it really matter if there is a hole in the front of the airbox. most of us take our time, so the install is pro looking anyways.
HAPPY NEW YEAR
Old Jan 3, 2005 | 07:50 PM
  #40
dibble9012's Avatar
I found this for a new intake, is this a good choice to buy for my 4runner? Looks too exposed to the elements, but I dont know. Any help would be great! I think this replaces the Intake silencer and the airbox, correct me if im wrong. Any other intakes that I should consider?
