CV Boot Replacement???
Old Jul 21, 2003 | 06:33 PM
Stump1883's Avatar
Does anyone know of a write up on replacing the inboard and outboard CV boots. I need something here, I have no idea about what I'm getting myself into, but I refuse to pay the $90+/hr. that the stealership would want to install them. Thanks in advance.
Old Jul 22, 2003 | 06:02 AM
Victor's Avatar
On my 2nd gen its pretty easy to pull the half shaft. Autozone has a replacemnt shaft for $70 or so. A lot easier than trying to put a boot on - you have to disassemble and do a ton of cleaning.
Old Jul 22, 2003 | 06:59 AM
AznSky's Avatar
I just got my fixed at the dealership, paid 245. I've seen a bunch of people that have said it's been easy to replace, but for some reason they have all been 2nd gens. If you do a search on here, my old thread had somebody post fully detailed instructions.
Old Jul 22, 2003 | 07:01 AM
TDiddy's Avatar
I believe 4x4wire has some threads about replacing a half-shaft as well.
Old Jul 22, 2003 | 04:07 PM
I recently changed my CV axle. I work as a mechanic during the summer and the guys I work with say that if the boot is ripped its worth paying the money for a new CV axle because the joints are already damaged and the time involved in changing the boots arent worth the hassle.
Have fun.
Old Jul 22, 2003 | 04:18 PM
WATRD's Avatar
Re: CV Boot Replacement???
It's a no brainer. Out with the old, in with the new, an hour a side, max. There is no point in changing the complete axle unless there is an actual problem with the joint itself. Replacing the entire axle for a torn boot is throwing the baby out with the bathwater...
http://www.keystonekrawlers.com/Mods...eplacement.htm
Old Jul 22, 2003 | 05:13 PM
channer's Avatar
I have a 2nd gen, and I opted to change the whole axle. about $80 at AutoZone.
I chose replacement for two reasons:
1 - To replace the boots you must remove the axle, and you need the proper tool to attach the new boot, along with grease, and it will probably take 2-3 hours.
2 - The replacement from AutoZone has a lifetime warranty.
It only took me about 1/2 hour to replace my axle, and now I have a new axle, two new boots (professionally installed) and a warranty.
Two new boots, tool, and grease is about $40, plus 2 hours of my time
vs.
New axle, new boots, grease, warranty, and 30 minutes of time $80
Just my $0.02.
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
BeMiceElf
Oct 10, 2015 09:40 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
1994toyota
Jul 17, 2015 03:03 AM
