Confused on cylinder#/misfire codes
Old 09-11-2008, 06:49 PM
alexh2's Avatar
Hi,
98 tacoma 3.4L.
I'm getting a PO304 code which is listed as cylinder #3 in my FSM.
However, I can't find any info on the cylinder numbering other than what's printed on the drivers sides plug wires and I don't know if these also refer to the codes.
Anyone know what the cylinder numbering is with respect to these codes?
I have seen posts refer to the firing order which does not match what's printed on the plug wires so I'm thoroughly confused.
Thanks
Old 09-11-2008, 06:58 PM
jason191918's Avatar
http://www.ncttora.com/fsm/2000/Repa...ngine/dtcc.pdf
Here it says it is #4 misfire.
And this covers the firing order.
https://www.yotatech.com/forums/f2/f...-4-help-47016/
Old 09-11-2008, 07:09 PM
alexh2's Avatar
You're right on the code, the 96 tacoma manual has a formatting error which makes it look like #3.
Thanks
Old 09-11-2008, 07:26 PM
no prob bob
Old 09-12-2008, 06:36 AM
97ltd4x4's Avatar
Yea,Its confusing because the wire numbers are showing the coil locations not the wire locations.
some drunk guy
08-03-2021 06:09 PM
Firefightersink15
11-23-2015 10:32 PM
Draven023
09-26-2015 12:41 PM
Boomer8404
09-20-2015 06:15 PM
Armstrong486
09-19-2015 12:37 AM
Quick Reply: Confused on cylinder#/misfire codes
