Confirming clearance
Old Sep 16, 2009 | 09:10 AM
bigpoppa's Avatar
I recently went up to a MT in the 285 75 16. I want to make sure that I am clearing the tire everywhere before I drive all the way to Barnwell to do some offroading. I have trimmed the flares, pounded the pinch weld and done everything I can think of to make sure that I clear these tires. Now I am not sure how to test it before I make the 2 hour trip to Barnwell Mountain just to find out I have alot of work left to do.
I have a high curb (about 16") next to the house. I put each of the front tires up on that curb and turned the wheel to full lock in each direction. I cleared the pinch weld and the flare in the front. I also put my floor jack under each of the front lower control arms and jacked the truck up and checked the clearances this way.
There really isn't anywhere that I can legally get offroad around the house. I just want to make sure I don't make a 2 hour drive just to have to spend all day under the truck with the BFH.
Old Sep 16, 2009 | 09:21 AM
Lumpy's Avatar
Well if you put each front tire up on the curb one at a time you should be alright...If you really that worried about a little rub do the same with the rear. One at a time.
If your still not happy take a cordless sawsall with you and cut out what you need while your out there.
Old Sep 16, 2009 | 01:37 PM
bigpoppa's Avatar
Thanks, probably will at least take the BFH with me. I don't have a cordless sawzall but I do have a corded one and an 1800 watt inverter. Hopefully I don't still have that much trimming left.
Old Sep 16, 2009 | 02:54 PM
scuba's Avatar
If you want the front to flex out you need to back the rear of the truck on that curb of yours..
Old Sep 17, 2009 | 06:35 AM
bigpoppa's Avatar
I guess that is true. putting the back up will compress the front more than putting the front up.
I'll try it if it ever stops raining.
Old Sep 17, 2009 | 06:39 AM
crolison's Avatar
You'll probably find more places it will rub on the trail, not bad though. Flexing it out like you've been doing will help you got about 95% the way there.
kawazx636
Oct 6, 2021 03:03 PM
scott90
Oct 4, 2015 09:21 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Odin
Sep 26, 2015 06:56 PM
Project90
Sep 24, 2015 11:40 PM
