Coil spacer question
Old May 28, 2003 | 11:05 AM
az4x4runner's Avatar
Question Coil spacer question
I have coil spacers in my rear coils, I put them in one of the bottom twist thingys of the spring, they've been there for a long time now and do help keeping it from being to much lower in the rear. I was curious though, if I were to install another spacer at the top.. that wouldn't leave very much free moving spring left, although I'm sure the spacers mush a little bit on bumps and stuff.. would this be bad? I know it'd be stiffer..
thanks...
-Bryan
Old May 28, 2003 | 12:51 PM
Question for ya wouldnt putting so many spacers make your truck reallystiff and bouncy??? my 99 truck is stiff enough. i was just curious though
Old May 28, 2003 | 12:55 PM
44Runner's Avatar
Re: Coil spacer question
thanks...
-Bryan
Sounds to me like you have trim packers, not coil spacers. Coils spacers are a whole different ball game. They just go on top of the spring (not inside the spring) and the spring keeps the same rate and length of travel, its just physically longer. That is where the lift comes from. Coil spacers are hard and do not compress...
Old May 28, 2003 | 04:33 PM
keisur's Avatar
thanks...
-Bryan
Just spend 120 bucks and get a pair of OME's. spacers cost almost the same as new springs.
Old May 29, 2003 | 01:38 PM
Re: Re: Coil spacer question
So having to many rubber packers would not only make it stiffer, but limit the amount of spring movement. I was just wondering if this would be bad for anything?
One day I will just get downey hd's, but I can't right now.
the1998sr5
15
Jul 14, 2020 08:35 PM
Numberonedad6
Jul 30, 2015 07:10 PM
4Runnin2000
Jul 29, 2015 06:09 PM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
