Clutch Problems
Old Oct 11, 2007 | 01:01 PM
haschen's Avatar
Clutch Problems
Ok first Problem.
Started truck this morning. Put it in gear and released the clutch (no gas applied) started moving forward! WTF.
Everything feels loose and strange.
For a while the truck has been whisteling and or whining but when i push the clutch in like a 1/8 of an inch it stops. Im so confused Please offer advise. Thanks
Old Oct 11, 2007 | 01:18 PM
pkt1213's Avatar
If you have it in gear and the clutch out it should move forward otherwise it would stall out.
As for the noise it could be your throw out bearing.
Old Oct 11, 2007 | 01:31 PM
jarboarder1's Avatar
If you let your clutch out fast and it didnt stall but slowly started to move forward then your clutch is slipping and probably on its last leg.
The noise is most likely your through out bearing.
By the sound of it you need to replace your clutch
Old Oct 11, 2007 | 09:14 PM
Skrillah's Avatar
Sounds like your slave cylinder is dead...or it could be your master clutch cylinder, I would actually bet on it. Do some searching on here and on ttora.com and you'll find out what I'm talking about. Not too uncommon....
Old Oct 11, 2007 | 09:52 PM
ozziesironmanoffroad's Avatar
mine slips a little bit, but i like how loose it is, ya know? check your throwout bearing and check your clutch cylinder... mine used to leak fluid into the cab.. yuck. is that happening?
Old Oct 11, 2007 | 10:32 PM
jason191918's Avatar
i dont think it's anything hydraulic related. if it was, it would have the opposite effect of slipping. for instance, a slipping clutch means you can have the clutch pedal out (engaged clutch) and the truck may not move. on the other hand, if the hydraulics were shot (MC, SC, etc) you wouldn't be able to disengage the clutch, and it would want to stall out anytime the truck is in gear and stopped. I know this cuz i my SC went out on me not too long ago...
hope this helps.
J
the1998sr5
15
Jul 14, 2020 08:35 PM
PlayAwhile
Jul 20, 2015 11:36 AM
1996Taco
Jul 20, 2015 12:02 AM
the1998sr5
Jul 16, 2015 06:20 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
