Clutch on a 2WD question
Old Apr 2, 2006 | 08:45 PM
djtech's Avatar
About to do my clutch and I have noticed that the crossmember cannot be removed on my model (97 2WD). Has anyone done a clutch on this type of truck. Can you just back out the tranny from the engine and leave it up on top of the crossmember to change the clutch or do you HAVE to turn it 90 degrees and drop it completely forward?
Thanks for the advice
Old Apr 2, 2006 | 09:12 PM
JamesD's Avatar
Just remove the crossbrace and it will slide back then drop down and forward. Actually not that bad to do.
James
Old Apr 2, 2006 | 09:23 PM
djtech's Avatar
So you don't have to turn it 90 degrees before you drop it down like the service manual says? Do you think there would be enough room to just pull it back and keep it jacked up there so I can get in and replace everything?
smthwsn357
May 1, 2024 07:28 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
1996Taco
Jul 20, 2015 12:02 AM
colasurdo
Jul 16, 2015 11:32 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
