Clock and Rear Power window share the same harness????
Old Dec 20, 2004 | 12:13 PM
Billabong's Avatar
I took my dash apart and just figured out that I only have one male harness to plug into either my clock or my rear power window button. Is there supposed to be some type of splitter so I can use both?
Old Dec 20, 2004 | 01:16 PM
Billabong's Avatar
bump.. i looked all over for another harness, but no luck... its NOWHERE to be found.
i have a 99 4runner sr5.
Old Dec 20, 2004 | 01:34 PM
Babypig's Avatar
Did your truck come with a clock?
The connectors should be very different.
Old Dec 20, 2004 | 10:04 PM
Billabong's Avatar
I bought my truck used... but yes, a clock is there but there no harness plugged into it. i discovered that the harness that plugs into the clock is the same harness that plugs into my rear power window button. so, when i plugged that harness into the clock, the clock worked, but then my window didnt work. I looked high and low for another harness to plug into my clock, but its nowhere to be found.
what can i do?? is there like a splitter harness almost like a 2 to 1 harness that i can pick up???
Old Dec 21, 2004 | 06:54 AM
jsteele's Avatar
From I've found they are seperate harnesses. The last time I pulled dash I must have droped/conviently mispplaced the clock harness and have not been able to find it. So I don't have a clock at this time. I thought that it should be attached to other cables bundled together but I could not find it. If you find it let me know.
Old Dec 22, 2004 | 07:39 PM
Billabong's Avatar
i dont understand how i wouldnt be able to find it though! its not something thats hard to miss. u know what im saying?? the wire loom its in is freaking thick!
Charecter1
Nov 6, 2023 10:08 AM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
icentropy
Jul 11, 2015 07:21 AM
coryc85
Jul 6, 2015 04:07 AM
