Cig. Lighter Quit
Old Oct 22, 2004 | 09:09 AM
4x4Lamm's Avatar
Unhappy Cig. Lighter Quit
I was topping of my spare with my compressor and it died, fuse was blown so I replaced it with another 15Amp blade fuse, it worked for about 5 seconds, then nothing again, only the fuse is intact.
Any Ideas?
Thanks,
Lamm
Old Oct 22, 2004 | 09:11 AM
ctcost's Avatar
Check the plug to the compressor Lamm...Seen those go bad 1000s of times.
Old Oct 22, 2004 | 09:17 AM
4x4Lamm's Avatar
Well I tried another acessory and it didn't work either, but thanks for the tip.
Lamm
Old Oct 22, 2004 | 09:24 AM
ctcost's Avatar
hmmm...maybe one of the wires was loose and caused the initial short...then gave out all together?
Good luck with it Lamm!
Old Oct 22, 2004 | 10:16 AM
Scottiac's Avatar
when mine did that it was the fusible link wire in the 12v adapter itself.
If so, you'll likely need to pull the center dash (pretty easy), and check the connection there... solder in some new link wire, or just some any-ole-wire (not my recommendation) and you should be good.
I have a reference somewhere... hmmm....
https://www.yotatech.com/forums/show...ible+link+wire
Old Oct 22, 2004 | 11:07 AM
4x4Lamm's Avatar
You da man Scott,
I let you know how it turns out
Lamm
Old Oct 22, 2004 | 04:15 PM
Corey's Avatar
Co-Founder/Administrator
Happened to me using an air comp too on my '90 truck I use to have.
Cut out the link and attached the two wires.
No problemo...
Stupid link is not needed and causes more snafus than it is worth.
Old Oct 22, 2004 | 04:23 PM
Jared Ajlouny's Avatar
mine went out....no fuse blown, had to put the key to off acc on over and over a few times. it started working than went out again. the tool i was using was drwing to much current....it works now tho
kawazx636
Oct 6, 2021 03:03 PM
irv
Sep 29, 2015 06:20 PM
taraf
Sep 25, 2015 02:57 PM
ToyotaMD
Sep 22, 2015 04:49 AM
