Chipped crackshaft still usable?
Old Jun 19, 2020 | 07:26 PM
92mn4runner's Avatar
I chipped the 3rd teeth to the right of the TDC mark, is this still re-useable?
Old Jun 21, 2020 | 06:07 AM
aowRS's Avatar
That is the crank sensor trigger wheel. A missing tooth will most definitely cause running issues.
Andreas
Old Jun 23, 2020 | 06:09 AM
Jomoka's Avatar
That's not chipped, that's missing. And yes, that will cause issues.
Vaguely possible it might run (poorly). More likely it won't even start.
The ECU watches pulses from the sensor caused by the teeth going past the sensor, and looks for long or short patterns in the teeth going by. A missing tooth will make it think the crank is in a different position.
Old Jun 23, 2020 | 06:25 AM
https://www.japanesetruckdismantling.net/v/vspfiles/photos/13521-62031-5.jpg
Thank you for the extra information. I went ahead and bought a new OEM crankshaft gear so hopefully I do t run I to any more unexpected issue. Only thing to do now is clean up the area and install the parts. Hopefully I can drive it this weekend.
Old Jun 23, 2020 | 05:09 PM
Did some more work today. I install the water pump, thermostat, cam gear and crankshaft seals today. I also found a way to use a socket to hold the camgear while I loosened the bolts
92mn4runner
10
Jun 21, 2020 12:37 PM
drkblu4runner
17
Oct 13, 2011 11:52 PM
pius222
21
May 22, 2011 01:35 PM
DavidA
19
Dec 3, 2005 07:00 PM
Vato Loco
20
Jan 5, 2005 08:02 PM
