Check out my 7" Panhard drop bar! :D
Old Dec 16, 2005 | 07:27 PM
sschaefer3's Avatar
Originally Posted by Robinhood150
Yup, I've always said that from the beginning. All the bend does is reduce the stiffness of the bar. A straight bar is stronger and won't deflect as much under load. Of course it doesn't matter if the bar is beefy enough.
The other thing is because the bar isn't horizontal the axle will shift left and right more as the suspension cycles rather than if the bar were horizontal.
Leaf springs brother, leaf springs.............................
The 3rd Gen stock rear suspension is designed to do one thing. Ride nice on the road. If you think it's anything other than that your crazy.
The rear leafs I have climb and flex twice what that stock suspension did. Cheeses new 4 link will be even better yet.
Bottom line does anything on Cheese's 4Link look anything like the 3rd Gen stock suspension. No.
I roll on the ground laughing at some of those old posts on 4X4Wire. Man were we all clueless.
Old Dec 17, 2005 | 12:22 AM
BajaRunner's Avatar
If the lengthened links wer added, would it effect overall pinion angle? Would the spring mounts also need to be re-welded to a different location?
eh.. Id probably do a leaf swap before going through all that... ? The torching off of all the mounts scares me though.
Old Dec 17, 2005 | 05:04 AM
sschaefer3's Avatar
That's the tricky part. No you would not have to cut anything off the axle. But basically you would do the lowers and then set the pinion angle and measure for the uppers.
Nothing you can do remote. You would have to be here in Arizona. I have 2 spare sets of uppers and one spare set of lowers, we would just have to sleeve the tube and make them longer. Not a big deal but your not here.
Old Dec 17, 2005 | 09:22 AM
BajaRunner's Avatar
I'll fly out there ?
Oh wait.
There has got to be a way of calculating it. Of course I dont have the correct tools to measure the angles between the links.
Old Dec 17, 2005 | 09:49 AM
  #25
sschaefer3's Avatar
I don't need you, I need the truck. You would have to drive here or find someone over there to help you.
Old Dec 17, 2005 | 10:27 AM
  #26
BajaRunner's Avatar
I know .. I was kidding!
It would be fun to drive there and go wheeling somewhere new!
Old Dec 17, 2005 | 07:31 PM
  #27
dragr1's Avatar
Looks good.
Sleaker
Aug 26, 2020 06:03 AM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
DrZero
18
Jul 24, 2015 11:31 PM
Sandman
Jul 14, 2015 12:36 PM
