Cheap 99-02 Factory Hella fog light color conversion
Old Oct 16, 2004 | 07:58 PM
2001Millrunner's Avatar
Today I took off my factory fog lights to clean the lenses because cheap H3 bulb actually Blew up in the housing! When i was clening this I thought, hey why not use a lighting gel to somehow change the color. They're used for stage lighting and are designed to withstand high-heat condition. I cut a small circle to match the size of the projector and inserted it in. After putting everything back together I turned on the lights...Holy ˟˟˟˟! it looks sweet! they look Identical to PIAAs if not yellower. I don't know about you guys but paying $40+ for PIAA Ion crystal is a royal pain in your wallet. And with this mod, I can even use a clear bulb which have way more bulb life. Another plus side to this is that I can change the colors to blue, red, yellow, or green, stack different colors and you can get purple(blue+red) and so on.
If you decide to do this mod, I wouldn't recommend go any higher than 55W bulbs due to high-heat situation.
I have put up a write-up/pics on my webshots account. Click link for my homepage and go in "lighting gel mod" folder
cost=$10 for 4(blue,yellow,red,green)lighting gels
final product
comparason with Hella Ion Crystal(yellow) bulbs, which doesnt look yellow at all
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
Johntom240
7
Jul 13, 2015 12:18 AM
