Changing power steering belt
Old Jan 15, 2005 | 12:24 PM
forum95's Avatar
I've searched but haven't found any write ups on changing a 2nd gen p/u power steering belt. It appears to me that I have to take off the fan shroud to change the belt. I am a little worried because it looks like it might be a little hard to reconnect the shroud back on. Some tips would be great if anyone has replaced theirs, thanks
-Andrew
Old Jan 15, 2005 | 12:37 PM
3car's Avatar
i just did mine this morning. the hardest part about removing the shroud is getting to the bolts. once their out, the shroud will come out fairly easy. the adjustment bolt on the ps pump bracket is hard to get to as well. i used a flex-head gear wrench, and did it a little at a time. im not sure if you HAVE to take the shroud off or not,, mine was already off due to other repairs.
Old Jan 15, 2005 | 02:11 PM
Glenn's Avatar
I have changed my power steering belt three or four times and have never taken the fan shroud off. You take the alternator/fan belt off first. Then loosen the bolt on the tensioner pulley bolt and then the tension bolt enough to take the belt off. This is for the 22RE. It might be different for the 3VZE.
Old Jan 15, 2005 | 02:47 PM
forum95's Avatar
I just got done replacing it, I dont have a set of those gear renches so I had to take out the battery, and it was a little easier to get to.
EDIT: hey glen I live in Federal Way
Old Jan 15, 2005 | 05:13 PM
93YODER's Avatar
I Changed The Power Steering belt On Mine. I Thought That I Had To Remove The Radiator,shroud And Fan So I Did And It Turned Out To Be A Big Waste Of Time.i Could Of Just Sliped the belt Around The Fan And Shroud.
Old Jan 15, 2005 | 05:25 PM
3car's Avatar
LOL, chalk it up to "experience".
Old Jan 15, 2005 | 05:31 PM
nyceride's Avatar
I don't think they fit around the fan....well mine didn't (3.0l) so I had to take it all apart.....and scrapped my knuckles up on the rad in the process.....I'd change both belts so you don't have to do this any time soon.
Old Jan 15, 2005 | 05:33 PM
3car's Avatar
it fits around the fan on the 3.0.
Old Jan 15, 2005 | 06:06 PM
Glenn's Avatar
It will fit around the fan if you maneuver the belt between the fan blades. No way that I can see removing the shroud is necessary.
Old Jan 15, 2005 | 11:15 PM
nyceride's Avatar
Hmmm....maybe I have the wrong fan on my 4runner? But my fan is huge, plastic, and there is no openings on the fan blade?? Its one plastic hoop with the blades inside?? Well the description sucks but someone will know what I'm talking about when they look at their 3.0 engine.....I thought it was weird looking myself and left me scratching my head.....like when I changed the fuel filter and the PCV valve....the WTF were they thinking followed....
Old Jan 16, 2005 | 03:40 AM
3car's Avatar
every time i work on my truck, i ask myself "WTF were they thinking".
Old Jan 16, 2005 | 07:09 AM
kennner's Avatar
You don't need to take the fan or shroud off. It takes a bit of time but you can wrangle the belt around the fan then between the fan and shroud. Thats the way it works on my 90.
Old Jan 16, 2005 | 12:25 PM
nyceride's Avatar
Well you learn something new every day and the next time I have to change my belts (PLEASE NOT ANYTIME SOON!) I will try to get the belts off this way.....But just a question your talking about the same fan right? Big white plastic fan thats one solid peice? No openings between each fan blade?
Old Jan 16, 2005 | 04:18 PM
kennner's Avatar
Thats the same ugly one. Looks like it should be in a hovercraft of something.
Old Jan 16, 2005 | 05:31 PM
nyceride's Avatar
haha yeah thats it....well now I know it can be done.
Old Jan 16, 2005 | 05:52 PM
Adam F's Avatar
Check it out. I wrote is just for you
http://www.toyotaoffroad.net/afertig/88/belts.htm
Sleaker
Aug 26, 2020 06:03 AM
cars-guy
Jul 11, 2015 07:51 PM
jon.r
Jul 11, 2015 03:34 PM
nick b
Jul 11, 2015 04:38 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
