Old Mar 30, 2016, 03:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Transmission Guides
Print Wikipost
Changing Manual Trans Fluid on a 2003 Tacoma 2.4?
Old Jan 11, 2005 | 06:02 AM
ugadawg95's Avatar
Can anyone point me in the right direction for a writeup? Is it pretty similar to Bob's writeup below?
Changing Your Manual Transmission Fluid
Thank goodness for manual transmissions: its a very simple drain and fill! As always, unbolt the drain plug first. Begin by placing your oil pan underneath the drain plug and then remove the bolt, located on the passenger side, with a 24mm socket. Next remove the fill plug, which is located on the driver's side. It's easier to use a crescent wrench here to remove the 24mm bolt. Place both bolts/washers in a safe location and let the transmission fluid drain.
Remove the 24mm drain plug/washer. This one is very easy to remove. Remove the 24mm fill plug w/ a crescent wrench. Space is a little tight here, but its doable.
After the transmission fluid comes to a slow drip, re-fasten the drain plug. Next, fill the transmission with 2.3 quarts (69 oz) of Amsoil 75W-90 Gear Lube. Replace the fill plug and then you're ready to move onto the front differential.
Old Jan 11, 2005 | 06:31 AM
EDGE's Avatar
do a search, manual trans is no different then an oil change just remove the fill plug 1st then the drain plug and replace with whatever fluid the owners manual says
Old Jan 11, 2005 | 06:32 AM
ugadawg95's Avatar
I did a search...not many 2.4 owners on this board it seems. Thanks!
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
mskalmus
May 28, 2017 07:51 AM
akaphilly
Jul 9, 2015 02:18 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
